    [Plugin] S4U ScaleTool
    19 Posts 8 Posters 27.0k Views 8 Watching
    • hdpvH
      hdpv
      S4u_ScaleTool:
      Current version: v3.0.0
      http://sketchucation.com/pluginstore?pln=s4u_scaletool
      http://extensions.sketchup.com/en/content/s4u_scaletool
      Tutorial video:
      https://www.youtube.com/watch?v=ofgDbH8SMXg%26amp;list=PLfw9P5m29pNQcWZfipT-YwilQktNvlhUW
      Update v3.0.0
      -Display units
      -Optimize code
      -Save input user
      Update v2.0.2 :
      Decimal symbol "." or "," is OK now.
      -Select groups or components for scale or push/pull distance(x,y,z axis).
      -Scale Fix length(x,y,z axis).
      -Reset scale.
      Suforyou
      http://www.sketchupforyou.com
      • O
        othmanalazzam
        nice, but how about scaling in other directions, x & y, and scaling from corner
        • hdpvH
          hdpv
          In other directions wait next version,scaling corner is too detail , i think no need
          Suforyou
          • KrisidiousK
            Krisidious
            Very handy for changing the multiple levels. very nice.
            By: Kristoff Rand
            • mitcorbM
              mitcorb
              I am interested to see how this develops. Good work 👍
              • ElibjrE
                Elibjr
                Nice Work HDPV! This looks promising!
                • hdpvH
                  hdpv
                  Thanks all! 😄
                  Update S4U ScaleTool v2.0.0 scale x,y,z axis.
                  Suforyou
                  • josephkim626J
                    josephkim626
                    Is it possible to implement "flip along" functions similar to the way scale works in this tool? I love how it scales multiple components at its own origin rather than as a whole.
                    I have tried giving -1 values to scale to produce "flipped along effect", but it isn't the same result as native tool's function.
                    • hdpvH
                      hdpv
                      "flip along" for multiple components use s4u-Transformer : set base center and scale ratio -1
                      http://extensions.sketchup.com/en/content/s4u-transformer
                      but it must purchase 😄
                      Suforyou
                      • josephkim626J
                        josephkim626
                        okay, thank you.
                          rv1974
                          Is it possible to add following mode:
                          1. on preselected geometry, run the script.
                          2. select edge (if it was clicked in upper area (A) it will scale 'upward', if in lower (B)
                            it will scale 'downward'
                          3. click desirable level.
                          4. preselected geometry get scaled up to the 'C' level.
                            What is the difference with use of the normal native Scale Tool of SU ? 😄
                            Or even FredoScale ? 🤓
                            It's less simple! 💚
                              rv1974
                              scale the all cubes (by Z axis) at once to the top of cylinder
                              Untitled.skp
                                Sorry I don't see the problem! 😲
                                That will be the same if I select all the cubes!
                                And it's not a good idea to make groups! 😄
                                As soon as you have 2 similar objects make a component! 🤓
                                See here you have a file of 1,6 megas
                                The same with component is 28O kB so quasi X/6 ! 😉
                                  rv1974
                                  All at once you were asked to
                                    So 😄
                                      rv1974
                                      Why don't you publish the gif with standard scale acting? Lately you tried to covince me how splendid standard scale tool is.
                                      Look I know how standard\fredo scale work and find it inappropriate in many cases (mainly because it demands too much stupid navigation efforts to find the right grip\ target point (and in many cases it tend to disappear completely).
                                      My idealworkflow eliminates the successive zooming in\out altogether.
                                        Yes but in this case you don't use correctly the objects!
                                        It's not the normal way to use mutiple copy of a same group!
                                        Even it's working with 780 entities but not 1070 with your curious config that don't work ?
                                        Ask Tig, Thomthom, Fredo...
                                        And with a component you have just to resize one component!
                                        So i suppose the developpers don't imagine your case!
                                        Multi numbers of tinies groups! 😄
                                          rv1974
                                          I don't get it,why keep on cheating non-stop. There's indeed a bug in scale behavior- grips tend to disappear plus it's hard to navigate while scaling distantly scattered objects. Why keep on denying the obvious?
                                          P.S. Please scale 2! (just 2) cubes in Z dir up to the big prism top with standard scale tool.
                                          pour mes collègues multicolore.skp
