    Steam Locomotive Cabin
    7 Posts 6 Posters 1.7k Views 6 Watching
    • L
      Lz
      http://i1308.photobucket.com/albums/s613/Lzoli18/sggsd_zps63b02d86.jpg
      http://i1308.photobucket.com/albums/s613/Lzoli18/Py27/2_zps72d51d5c.jpg
      Latest 3d model. should have done better/more renders but my PC is so painfully slow (especially with complex materials). starting to look like a broken record, but here is yet another loco. No plugins used. i decided to include and name cabin controls and detail them if anyone is interested. almost every component is named so here they are.
      http://i1308.photobucket.com/albums/s613/Lzoli18/Py27/insideb_zps2604d625.jpg
      LEFT============
      Rvs - Reverser handle. Controls the direction of the engine, almost like a gear shift on a car. It can either be turned forward, backward or positioned on idle.
      Brk - Brakes. When activated, six brake shoes are applied, one for each wheel. Like the brakes on a bike, it takes awhile for the brakes to slow down the vehicle.
      T - Measurement taps, used to measure the exact water level inside the boiler.
      R - Regulator lever. Works as a sort of throttle, controlling the amount of steam that gets into the cylinders. The cylinders blocks are those two motors on either side of the loco that drive the wheels.
      S - Sanders. When pulled, it releases sand in front of the wheel from a dome placed atop the boiler, increasing traction and preventing wheel slip. Rails don't offer much traction, so this definitely helps, especially on rainy days.
      W - Whistle, steam powered.
      I - Injector controls. This tool injects fresh water into the boiler from the water tanks when needed. Without a supply of water, the engine steadily crawls to a halt. Water is stored inside the two side compartments located outside the cabin.
      RIGHT=============
      A - ashpan levers. Opens a trap door underneath that releases ash and other residue resulting from the fire
      Pb - plate bolts. Fastens the outer plates to the boiler
      F - firebox door
      Wg - water gauge. measures the water level inside the boiler. a protective outer shell is fastened to it in case the glass shatters (hot water and shards of glass tend to hurt). Not always a reliable tool when climbing or descending a hill. The three taps are used to equalize the water to show a correct measurement, or shut it off completely if necessary.
      P - Pressure gauge. measures the pressure inside the boiler.
      I - Injector controls. See above. Why there are two of these on either side of was always a mystery to me. I suppose it's because if one crew member is busy, the other one can inject water or it might be a fail safe mechanism, or both.
      B - Blower. blows hot air unto the fire, increases its temperature.
      O - Oilbox handle
      http://i1308.photobucket.com/albums/s613/Lzoli18/Py27/3_zps6842e86f.jpg
      http://i1308.photobucket.com/albums/s613/Lzoli18/Py27/5a2_zpsc288bcb3.jpg
      http://i1308.photobucket.com/albums/s613/Lzoli18/Py27/7_zps64a5aa9e.jpg
      http://i1308.photobucket.com/albums/s613/Lzoli18/Py27/5a_zpsfbe3c509.jpg
      http://i1308.photobucket.com/albums/s613/Lzoli18/Py27/6_zps0b837d73.jpg
      http://i1308.photobucket.com/albums/s613/Lzoli18/Py27/5b_zps3f83279e.jpg
      http://i1308.photobucket.com/albums/s613/Lzoli18/Py27/9_zpsb586132e.jpg
      http://i1308.photobucket.com/albums/s613/Lzoli18/Py27/9b_zpsd13e80a5.jpg
      http://i1308.photobucket.com/albums/s613/Lzoli18/Py27/10_zpsa171e8aa.jpg
      http://i1308.photobucket.com/albums/s613/Lzoli18/Py27/9d_zps0c415887.jpg
      http://i1308.photobucket.com/albums/s613/Lzoli18/Py27/9f_zps11f76437.jpg
      http://i1308.photobucket.com/albums/s613/Lzoli18/Py27/9h_zps139bab36.jpg
      [url=http://s1308.photobucket.com/user/Lzoli18/media/Py27/11_zps4fe96c20.jpg.html:rauoy8js][img:rauoy8js]http://i1308.photobucket.com/albums/s613/Lzoli18/Py27/11_zps4fe96c20.jpg[/img:rauoy8js][/url:rauoy8js]
      [url=http://s1308.photobucket.com/user/Lzoli18/media/Py27/9e_zpsebcbff25.jpg.html:rauoy8js][img:rauoy8js]http://i1308.photobucket.com/albums/s613/Lzoli18/Py27/9e_zpsebcbff25.jpg[/img:rauoy8js][/url:rauoy8js]
        Excellent! πŸ‘ 😎
        No plugins used.
        You are a purist! πŸ˜„
        Jean Gabin in "La bΓͺte humaine" by Jean Renoir from Emile Zola
        http://image.toutlecine.com/photos/b/e/t/bete-humaine-1938-08-g.jpg
        • L
          Lz
          I heard of that movie πŸ˜„
          • pbacotP
            Phenomenal!
            • hellnbakH
              hellnbak
              πŸ‘ πŸ‘
              • allanxA
                allanx
                One of the greatest modeling I have seen in a long time here...
                allanx
                Portfolio
                • ken28875K
                  ken28875
                  Very nice model, Lengyel. I love your attention to details. πŸ‘ πŸ‘
                  Cheers!
                  _KN
                  Follow Your Dreams.
