    Problem about ruby searching path in sketchup
    9 Posts 5 Posters 1.1k Views 5 Watching
    • W Offline
      wikii
      When I install Sketchup in folder on other drive like d:/sketchup2014.
      I found the searching path is wrong.
      ["C:/SketchUp 2014/Tools/RubyStdLib", "C:/SketchUp 2014/Tools/RubyStdLib/platform_specific", "D:/SketchUp 2014/Tools", "C:/Users/wikii/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins"]
      "RubyStdLib" and "platform_specific" direct to 😄
      And Encoding.aliases return very few
      Encoding.aliases
      {"locale"=>"ASCII-8BIT", "external"=>"UTF-8", "filesystem"=>"ASCII-8BIT"}
      that leads lots of error like
      Encoding::Converter.new("GBK", "UTF-8")
      Error: #<Encoding::ConverterNotFoundError: code converter not found (GBK to UTF-8)>
      that is so depressed!
      any way?
      wikii
      • tt_suT Offline
        tt_su
        This is a bug in SU2014 M0 where the load paths will be incorrect if you launch SketchUp via a shortcut or SKP file that is on a drive different from where SketchUp is installed.
        There should be a fix in the next release.
        Until then the workaround is to launch SketchUp via a shortcut on the same drive SketchUp is installed to.
          Brighter3D
          I just ran into the same problem by myself.
          Thanks for explanation.
          • W Offline
            wikii
            Thank you!
            Wish next release come soon.
            wikii
            • tt_suT Offline
              tt_su
              Me too!
              Sorry for the inconvenience.
              • kenK Offline
                ken
                @tt_su said:
                Me too!
                You answered my question in another post. I use XnView to find models I wish to insert into others projects. I will from now on, open Sketchup first. This may clear up some problems I have that others don't appear to have.
                Thanks for your rely
                Ken
                • W Offline
                  wikii
                  I want to write a patch in ruby to solve the problem.
                  I put path.rb in Sketchup tools folder.
                  path.rb
                  drive=$;.clone.delete_if{|x| !(x=~/Tools$/)}[0][0]
                     path=$;.clone
                     $;.clean
                     path.each{|x|
                        if x=~Regexp.new("C;/SketchUp 2014/Tools/RubyStdLib") or x=~Regexp.new("C;/SketchUp 2014/Tools/RubyStdLib/platform_specific")
                            $;.push x.gsub(/^C/,drive)
                        else
                           $;.push x
                  But it seems too late.
                  But it seems Sketchup has missed launching something before loading "path.rb".
                  • Dan RathbunD Offline
                    Dan Rathbun
                    I've already written a patch, and TIG has updated it twice.
                    See: Re: Sketucation plugin load error
                    I'm not here much anymore.
                    • W Offline
                      wikii
                      Thank you!
                      I use the patch,but there is still different.
                      when sketchup install in drive c,and start with shortcut in desktop
                      Encoding.find("locale")
                      #<Encoding;GBK>
                      when sketchup install in drive c,puts the patch file in tools folder,then start sketchup with shortcut in desktop
                      #<Encoding;ASCII-8BIT>
                      This different will lead some error if filename uesed some Chinese character.
                      The patch file is still missing something?
