    Any smokers here? Wanna quit?
    822 Posts 42 Posters 215.2k Views 42 Watching
    • FrederikF Offline
      Frederik
      I still haven't learned to like the smoke from these wapers... ๐Ÿ˜
      I saw this animation the other day and will start practicing that instead... ๐Ÿ˜†
      Cheers
      Kim Frederik
        kwistenbiebel
        @Frederik, that is quite a skill ๐Ÿ˜„, reminds me to re-watch Seinfeld, still a good no brain series ๐Ÿ˜„
        @Olishea,
        Besides the beveled top, a provari looks sweet and I like it's small form factor. The Kayfun seems to like it too ๐Ÿ˜„, nice pictures. I like my Kayfun clones a lot , they are hassle free and consistent as opposed to clearos like errrr...protanks 1,2 or 3 , the heads seem to be hit and miss.
        I just bought a Touchwood handcrafted mechanical box mod . 18490 battery sรฎze.
        Loving the feel of it and it vapes really well with that detonator style button.
        Rocking it with the simple (and cheap) Igo-L dripping atomizer. Yummy ๐Ÿ˜„
        http://i.imgur.com/oQhHlUa.jpg
          mwm5053
          Finally got me a rebuildable mod from TKO a chain of vape stores across US. It has a 2.2 amp atomizer and I'm trying to find a good voltage and amp setting as you can change both with this mod. Not really sure yet what does what as far as the settings go maybe someone can shed some light on the subject for me.
          2011 iMac
          SU 2015 Pro, 2017 Make
          V2 Twilight
          macOS Sierra 10.12.5
          • stefanqS Offline
            stefanq
            Walt, good job with the mod, it's a good choice. However, be careful with the firing button, it's the weakest part. I'm not saying it will fault, but it's the most common fail of this mod.
            Regarding the way you can set this, I would recommend watts. Because, once you find "the sweet spot" for you, you don't need to adjust nothing any more, not even when you put another atomizer on the mod. It will give you the same vaping experience, with every hit you take. Start with 6 watts, then go up to 7,8 and so on, until you are satisfied.
            Cheers,
            Stefan
            • F Offline
              Futurepast
              SCORE!!!!!Went to a garage sale got a bag of about 50 2 ohm cartos for my ProVari for a $1
              • GarethG Offline
                Gareth
                Bargain...!! ๐Ÿ˜†
                • olisheaO Offline
                  olishea
                  ๐Ÿ˜
                  http://sincemylastcigarette.com/banners/1362072600_20_1_GBP_7.25_dark.png
                  oli
                    kwistenbiebel
                    Bargain! ๐Ÿ˜„
                    There are some good Carto tanks on Fasttech, I personally love the X8 as it is small and has a screw to prevent the carto to slide out, very handy.
                    Concerning cartos, I am sticking to double punched Boge LR cartos.
                    All the others seem to lack needed airflow.
                    Cartos really are a more consistent vape than clearos imo.
                    The only hassle is filling carto tanks, such a mess lol ๐Ÿ˜„
                    • stefanqS Offline
                      stefanq
                      Congrats Oli! ๐Ÿ˜
                      • F Offline
                        Futurepast
                        ๐ŸŽ‰
                        • olisheaO Offline
                          olishea
                          @Olishea,
                          Looks awesome Chris! I bet you're loving it. There's something reassuring about a big box mod, you just know it's built to last. The detonator button is cool!
                          Yeah I also noticed that about the Protank coils/heads. Some of them last a couple of weeks while some fail after a few days. I was in a bar drinking when one failed, I nearly went home to get another coil!
                          So, after a brief stint using kanger protanks/BCC, I am back on the old faithful Kayfun. ๐Ÿ˜„ Only problem is, my filler valve is completely blocked, so I have to unscrew the top to fill which causes it to flood and lose some liquid. Think I need to buy a new Kayfun at some point, they've got rid of the filler valves on the side now.
                          I also found a great spearmint flavour that I use for my DIY liquid. It's not menthol, just smooth spearmint flavour. I like to add some to my Juicy Fruit chewing gum flavour. Yum yum!
                          oli
                          • GarethG Offline
                            Gareth
                            well done Oli ๐Ÿ‘
                            I recently bought some Aspire BDC Vivi Nova's with glass tanks. They have an exterior metal sleeve (in assorted colours).....in certain light conditions, and especially with some of the clear liquids the two small and thin 'windows'are probably too small to see how much liquid is in the tank, but the vape is very good.
                            • olisheaO Offline
                              olishea
                              Looks nice Gareth! I'm jealous of your big batteries! ๐Ÿ˜†
                              How are you getting on? I found the atomizer to be really good, it's the innokin iclear right? I had one as a freebie and I used it until it stopped working, just never got round to buying coils for it.
                              Still using up my EVOD coils; I have found these later version coils (with the extended chimney) are very hit and miss. I thought I was imagining it but other people have reported the same issues. Maybe they want them to fail quicker so you just buy more.
                              Think I'm gonna get another Kayfun. The filler valve on my current 3.1 ES is so annoying. My next one will be the Kayfun Lite Plus which has a filler port at the bottom that you just unscrew; I think The Russian 91 is also like this. In fact I think my Kayfun 3.1 ES has been discontinued for this very reason.
                              http://www.cloud9vaping.co.uk/epages/yxve46fvrnud.sf/en_GB/?ObjectPath=/Shops/yxve46fvrnud/Products/SM-KF-LITE-PLUS2
                              I also really like the look of the Luxe mod with Kayfun on top, but for now my Provari is more than adequate, I can't see a reason to change.
                              oli
                              • olisheaO Offline
                                olishea
                                I think it's a case of really wanting to quit as well. If you aren't ready I think you'll always prefer a cigarette. Whereas for me, I feel sick even thinking of smoking a cigarette. I know vaping will never be the same, but I've learnt to prefer it. Not just the flavours and cool gadgets, but the flexibility to just take a couple of drags here and there....especially while waiting for computer to render etc.
                                Which vape setup have you been using by the way? Could it just be you don't like the flavours? Or is the vapour too smooth or too harsh?
                                oli
                                • GarethG Offline
                                  Gareth
                                  Thats a good point Oli.
                                  Good equipment is important, but finding good vapes in the early stages pretty well sets up the path of interest and persistence.
                                  I bought some absolutely crap nicotine liquids which took about 4 or 5 weeks to arrive, in the meantime I was vaping some quite nice non-nic liquids. Whilst I wasn't getting the nicotine hits I needed at that stage, I did find some pleasant flavours which I was then able to order from the US with nicotine in them.
                                  For those who don't understand what I just said, in Australia we can't buy nicotine liquids from Australian suppliers, but they do however sell liquids made in the USA which are nicotine free. This gives us the opportunity to test those flavours and either buy them direct from the US supplier, or alternatively mix an unflavoured nicotine (which we also have to buy from overseas) with the liquids in Australia which can be bought as 'doublers'.
                                  However, because we can't easily purchase liquids, one could easily be discouraged from persisting.
                                    kwistenbiebel
                                    Hi Gareth,
                                    I went through the same, starting with 0 mg nic juice (aaah..Australia ๐Ÿ˜„), and while waiting for nic juice from the States discovered some tasty flavours.
                                    The anticipation of that together with the great testimonies in this thread made me so eager to quit smoking, that it all just happened spontaneously. ๐Ÿ˜„
                                    It does make me wonder if I shouldn't go the 0 nic route again now and see what happens.
                                    I believe I can do it, especially with the latest drippers out there with huge air holes (Trident etc...), zero nic might still be a very satisfying experience.
                                    • GarethG Offline
                                      Gareth
                                      Glad you are staying with it mate.
                                      I still have one or two nice non-nic flavours from when I started in October and vape them occasionally. I can vape them for an hour or so, but I still want the 'nic kick' though...!
                                      I'm still vaping 18mg and should probably try cutting down to 12mg soon.
                                      Tried an analogue stinky a few days ago....took 3 drags of it....it was disgusting....!!
                                      • soloS Offline
                                        http://i1.cpcache.com/nocache/product/280429932/high_five_im_1_year_smoke_fr_mousepad.jpg
                                        I did it, one year and counting, technically I did it on the 3rd (it's the 3rd in Australia so it counts)
                                        I will never smoke again.
                                        • GarethG Offline
                                          Gareth
                                          Well done Pete ๐Ÿ˜
                                          How are your energy levels, sense of taste, general well being etc after 1 year...?
                                          • soloS Offline
                                            @gareth said:
                                            Well done Pete ๐Ÿ˜
                                            Energy level is great, no coughing in morning, office smells great, and I now have a new appreciation for cheese and wine.
                                            I can smell a smoker a mile away and they gross me out. ๐Ÿ˜•
                                            Oh, I also saved over $2000 this last year.
                                            • 25
                                            • 26
                                            • 27
                                            • 28
                                            • 29
                                            • 41
                                            • 42
                                            • 27 / 42
