    Specific selecting
    1 Posts 1 Posters 191 Views 1 Watching
    • robertWanR
      robertWan
      How can I make my work easier?
      I export file DXF from SU to machine CNC.
      http://www.screencast.com/t/avDahE0I
      Points for drilling are inside the components (green and blue circles).
      Now I do it this way:
      • I select all the components (furniture fitting) on the side of a wardrobe (scene - Side cabinet)
      • EXPLODE
      • I turn off layer Fitting
      • manually erase circles, which aren't lying on the side of the wardrobe
      There is a plugin Select Edges by Z made by TIG.
      http://sketchucation.com/forums/viewtopic.php?t=20633
      But it doesn't work with groups and components.
      There's a plugin AutoComponentSelection by sdmitch.
      http://sdmitch.blogspot.com/
      It selects the components lying on selected surface, but also those lying above it.
      What I need is to select only those lying on the indicated surface (wardrobes side).
      Below there is a recording of the mentioned plugins working.
      http://www.screencast.com/t/bfMBFMT0N
      Is there a plugin that would select only those groups/components lying on the selected surface of group?
      A perfect solution for me would be the possibility to erase, within one operation, all of the components/groups lying on the selected surface except for those being a part of a layer e.g. X.
      Robert
      How to make films from links from Jing (swf)?
      select.skp
