    V5 Beta MOI 3D on MAC / PC April 2022 !
    207 Posts 13 Posters 199.0k Views 13 Watching
      A new v3 beta (version Nov-5-2012) is now available for download here: http://moi3d.com/beta.htm , also linked to from the download page on the main web site. β˜€
      New stuff:
      Mac version should now work fine with the latest OSX system updates 10.8.2 and 10.7.5 without needing any other settings adjusted.
      New DXF file format support for import and export - focused on curve entities like lines, polylines, arcs, circles, splines. Should help with data transfer to and from various 2D CAD programs. When exporting you can choose to export either a 2D projected view which will flatten the curves by a view projection, or to export the 3D curve data. It's saved as an AutoCAD 2000 version DXF file.
      Updated closed surface skinning to do periodic closed surfaces - fixes problems with closed fillets, blends, and sweeps where the generated surface was not smooth at its closing seam area. One recent one reported here: http://moi3d.com/forum/index.php?webtag=MOI&msg=5376.1 which should now be smooth in the seam area where there was a crease happening previously.
      Fixed a regression in the last geometry library update that was causing failures with analytic intersections between planes and cylinders and preventing some Booleans from working. Also fixed another regression that was messing up Inset as reported here: http://moi3d.com/forum/index.php?webtag=MOI&msg=5508.1
      New "Bounding box center" button for Transform > Move, Copy, Scale, and Scale1D commands. On the first prompt where you can pick the base point for these transform commands there is now a "Bounding box center" button you can push to use the center of the object's bounding box as the base point, to make it easier to move the object's center point to a specific location.
      Update properties panel size readout - units calculator. Make the units label in the size: line of the properties panel to be clickable separately, when clicked it brings up a mini units calculator that allows displaying the size in different unit systems.
      Requested on the forum here: http://moi3d.com/forum/index.php?webtag=MOI&msg=5503.1
      Demo here: http://moi3d.com/forum/index.php?webtag=MOI&msg=5503.14
      It's also now possible to have a script change which units will be used inside of the top-level size: line inside the properties panel, here's a keyboard shortcut that switches the display in that one area from the current unit system to inches or back again:
      script: /* Set property panel units display */ var sp = moi.ui.sidePane; sp.g_PropPanelUnits = (sp.g_PropPanelUnits == 'Inches' ? '' : 'Inches'); sp.UpdatePropertiesPanel();
      Relabeled the vertex normals options for LWO format to make one setting labeled as "Modo 601 / LightWave v10" style normals, since as of Modo 601 it uses the same style as LightWave v10 for importing LWO vertex normals.
      Updated Extrude to point - when extruding a line segment to a point, make a trimmed plane for the triangular face generated rather than a surface with a singularity (collapsed edge) at the tip.
      Updated tapered extrude - added a "flip" checkbox, requested on the forum here: http://moi3d.com/forum/index.php?webtag=MOI&msg=5403.1
      Updated tessellator to fix triangulation issues in certain circumstances to fix the meshing bug reported on the forum here:
      http://moi3d.com/forum/index.php?webtag=MOI&msg=5365.4 also fixed a crash bug in the tessellator reported here:
      http://moi3d.com/forum/index.php?webtag=MOI&msg=5515.1
      Updated curve antialiasing - new option for using thinner style antialiasing in the display engine. Can be set in moi.ini under:
      [View]
      UseThinAntiAliasing=y
      Or toggled by a keyboard shortcut with: script: /* Toggle thin anti-aliasing */ moi.view.useThinAntiAliasing = !moi.view.useThinAntiAliasing;
      Was requested on the forum here: http://moi3d.com/forum/index.php?webtag=MOI&msg=5370.1
      New project to cplane drawing aid - Implement new drawing aid mode which can be used to project all snap points onto the construction plane, by using the following scripts on a shortcut key:
      script: /* Toggle projecting snaps to CPlane in ortho views / moi.drawingAids.projectToCPlaneOrtho = !moi.drawingAids.projectToCPlaneOrtho;
      script: /
      Toggle projecting snaps to CPlane in ortho and 3D views */ moi.drawingAids.projectToCPlaneAll = !moi.drawingAids.projectToCPlaneAll;
      Requested in forum here: http://moi3d.com/forum/index.php?webtag=MOI&msg=5371.1
      Updated Network surfacing command - fixed bug where the new fitting options from the previous beta did not get applied to 3 or 4-sided networks since those were handled by a special case Coons patch method instead. Now 3 or 4 sided networks will generate a regular Network surface with the same option in effect, and there is a new "Exact" option which shows up for 3 or 4 sided networks which will make a Coons patch with no refitting of the input curves.
      Fixed a bug where the main window did not store its size properly if the window was closed while it was minimized, when closing it by right-clicking on the Windows task bar.
      Fixed a bug importing spheres and surfaces of revolution from Rhino when certain additional rotation properties were set on them, fixes a bug reported on the forum here:
      http://moi3d.com/forum/index.php?webtag=MOI&msg=5389.1
      Updated ArrayGem - allow point objects to also be selected as target objects for creating copies instead of only path curves.
      Some scripting fixes - fix problem in function signature for moi.vectorMath.createFrame() that caused different behavior when arguments were left out between Windows and Mac, disabled script timeout that would abruptly cancel scripts that ran a tight loop for too long, fixed problem where pasting a script fragment into the xyz coordinate box would evaluate it twice, and make factory.getCreatedObjects() work with async factories by waiting for the async factory to finish its work before returning back to the script with the generated objects.
      Updated installer - put full version name on the "MoI" program shortcut so that multiple versions will be more distinctly labeled when they show up in the MRU area of the Start menu. Fixes the problem reported here: http://moi3d.com/forum/index.php?webtag=MOI&msg=5405.9
      Various other minor fixes.
        You must go there for a new beta of 6 NOV 2012 format SAT/IGES/STEP have some crashes!
          9 nov 2012
          Interview! of Michael Gibson the creator of Moi! πŸ’­
          He speaks also of Sketchup πŸ˜‰
          Another one but text πŸ˜‰
          http://www.novedge.com/blog/Michael_Gibson.jpg
          http://moi3d.com/forum/get_attachment.php?webtag=MOI&hash=78af5c65a1fca1b70e904ce777f27d08&filename=MichaelAndJoJo.jpg
          Have you try that inside Moi3D? πŸ’š
          CTRL + SHIFT + Click on the Options' icon? πŸ˜„
              Beta V3 03 18 2013
              (full detailed functions on the link πŸ˜‰
                Moi3D beta V3 first August 2013 (only for owners of the V2 ! )
                News: Blend Multiple! πŸ‘
                http://s6.postimg.org/4teyh945t/three_side.jpg
                Of course you can have any number! 3 to 5 for example! β˜€
                No time for detail, I must load the trailer! πŸ’š
                http://www.mistertuto.com/wp-content/uploads/2011/05/caravane-243673.jpg
                  Moment of Inspiration the Zen Nurbs modeler πŸ˜„
                  moi beta V3 19 Nov 2013 (only for owners of the V2)
                  The main new thing is hidden line removal when exporting to AI, PDF, and DXF formats.
                  Shift while drawing now works for an enhanced straight snap. When you hold down shift straight snap will have priority over object snap, and the current straight snap line will stay locked on for as long as you hold shift. Also when you hold down shift straight snap will activate to the closest straight snap line regardless of how far away it is to the mouse.
                  AI format for clipboard transfer should work on on OSX.
                  Some bugs fixed in surface/surface intersection, some cases that didn't work before with things like 2 pipes crossing each other should work better now.
                  Layers are exported to DXF format
                  Bug fixes to Blend between 2 edges that touch each other at sharp "pole points", and to order sorting for loft to point.
                  http://moi3d.com/forum/get_attachment.php?webtag=MOI&hash=cc76e7258aed4df2e587ac3c841f670a&filename=Reduced opacity-grey silhouette.png
                  Render with C4D
                  By Samardac
                  http://imageshack.us/a/img801/536/cffa.jpg
                  http://imageshack.us/a/img96/1121/wrvm.jpg
                    With new export Ai πŸ˜‰
                    By Martin
                    http://moi3d.com/forum/get_attachment.php?webtag=MOI&hash=f9ea24911fd9707ba61cb616c79f572e&filename=tremolo.png
                    http://moi3d.com/forum/get_attachment.php?webtag=MOI&hash=7497c251aa573bb9b5e8333df07c2eda&filename=vise.png
                      The complete list of new stuff of the Beta V3 of 19 November 2013
                      By Stefan
                      http://moi3d.com/forum/get_attachment.php?webtag=MOI&hash=d6499f2f46eae059fd216a2ed3ab0e3d&filename=it.png
                        For some customize of the UI, shortCuts plugins, Snapshots, Lightings... by Max Smirnov 😎
                        πŸ€“
                        http://moi3d.com/forum/get_attachment.php?webtag=MOI&hash=4c84be37b3802682e7e3205e25353924&filename=ObjLib.png
                        You can put any numbers of librairies and any numbers of objects! 😎
                        My little test ! πŸ’š
                        http://moiscript.weebly.com/uploads/3/9/3/8/3938813/7819703.jpg
                          Variable fillets announced for more voluptuousity! πŸ˜„
                            Moi Beta V3 03 24 2014
                            Ok owners of the V2 can have variable fillets! β˜€
                              http://s6.postimg.org/7x3o140y9/aprilfish.jpg
                              April's Fish πŸ’š
                              Maybe ScriptArray can help for some many things! πŸ˜„ because basic Transform / Array / Circular has not Size parameter inside!
                              ScaleArray has not the rotation
                              Just edit the header of the page for the 3 functions Move, Size, Rotate! (like Grow By TIG β˜€ but some different πŸ˜‰
                              Draw original ellipse on Right View following your parameters : here movement will be on the X
                              Movement of the original on the X will be : 5, 10, 15,...
                              Size of the original will be on Y, Z : size y2 size z2, size y3 size z3, size y4 size z4,...
                              Rotation of the original will be: 10Β°, 20Β°, 30Β°...
                              Advantage : you can input any formulas and parameters, any conditions... you want! πŸ˜„
                              http://s6.postimg.org/u6hl7nwep/scriptarray.jpg
                              http://s6.postimg.org/iinjd479t/helix2.jpg
                                Beta v3 06 27 2014
                                For owners of a license πŸ€“
                                List of news πŸ˜‰
                                http://moi3d.com/forum/get_attachment.php?webtag=MOI&hash=bfa21c5ff04c8dbcc1bb8f8b9b40e619&filename=ExtrudeAutoBoolean.gif
                                • olisheaO
                                  olishea
                                  Nice, my demo's just finished so I'm gonna buy a license. Great software and so easy to use.
                                  oli
                                    Bienvenue au club! β˜€
                                      Distord a curve (s) by Smirnov
                                      By Samardac
                                      • olisheaO
                                        olishea
                                        cool feature!
                                        oli
                                          Iso Curves Multiple!
                                          http://s6.postimg.org/g9e9ewdw1/multi_iso1.jpg
                                            Random Curve Generator
                                            By Max Smirnov πŸ˜„
                                            http://www.youtube.com/v/lRNMstKQUQw?
                                            http://moiscript.weebly.com/uploads/3/9/3/8/3938813/4571683_orig.jpg
                                            Delcorners
                                            http://s6.postimg.org/yxc51as0h/delcorners_en.jpg
                                            • 11
                                            • 2 / 11
