    Trimble makes blocks from sand, bacteria, calcium and PISS!
    6 Posts 4 Posters 1.6k Views 4 Watching
    • Mike LuceyM Offline
      Mike Lucey
      The Trimble in question is Peter Trimble, a graduate of the University of Edinburgh.
      For his thesis project he investigated if it was possible to grow building material instead of using mining and intensive heat and it proves to be the case.
      A summary of the project may be found here, http://www.wired.com/design/2014/01/stool-built-sand-bacteria-urine/#x
      • BoxB Offline
        That explains why the sweaty socks are always taking the piss.
        • jeff hammondJ Offline
          i think i'll leave out the redneck solution for wood filler when someone makes a mistake but, if any of you all ever happen to be on a jobsite of mine and make a mistake, i'm sure i'll let you know about it then. πŸ˜„
          • mitcorbM Offline
            mitcorb
            Would the redneck solution fix it in a New York minute? πŸ’š
              Mike Lucey
              Jeff, maybe you should get working on an alternative solution for concrete manufacture using the 'redneck wood filler'. I imagine it could make you a fortune as there is an abundance of it around and the local authorities spend a lot of money getting rid of it πŸ˜„
                @mike.. you're either up too late or up too early..
                either way, get to bed!
                πŸ˜„
