    Model 'Tea Tin' for Pay
    38 Posts 13 Posters 2.6k Views 13 Watching
    • gillesG Offline
      gilles
      @frederik said:
      Although I haven't setup materials for Vray, here's a quick model I made in less than 10 minutes (incl. the render in Thea)...
      I hope you can use it...!?
      Not sure I understand why you can't make such a simple model yourself, especially since you've set your SU skills to Advanced... 😐
      As long as somebody do the job for you. πŸ˜’
      • FrederikF Offline
        Frederik
        @mooarchi said:
        I need it both w/the photo texture mapped on, as well as a version with two textures (the black on the tin and the gold rim) so I can render it using VRay.
        Although I haven't setup materials for Vray, here's a quick model I made in less than 15 minutes (the render in Thea incl)...
        Size according to your info, but there's so many things, where I needed to eye ball (is this the correct term??) it and model...
        Not sure what you mean regarding "w/the photo texture mapped on"...?? πŸ˜•
        Any way... I hope you can use it...!?
        Side note...
        Tea-Tin.skp
        Cheers
        Kim Frederik
        • FrederikF Offline
          Frederik
          Had a little spare time to make a few adjustment to the lid and base... πŸ˜„
          Again... Materials are setup to use with Thea Render, so you'll need to adjust them for Vray yourself...
          They're UV-mapped as cylinders, so you should be able to use a photo-texture... πŸ˜‰
          Tea-Tin_v2.skp
          Cheers
          Kim Frederik
          • JQLJ Offline
            JQL
            Frederick,
            Words for what? Master at work! FAST! I had to check to see if it was the same picture!
            www.casca.pt
            Visit us on facebook!
            • FrederikF Offline
              Frederik
              @JQL πŸ‘ πŸ˜„
              Cheers
              Kim Frederik
              • pbacotP Offline
                I gather OP has lots to do and can use a little side help now and then.
                • FrederikF Offline
                  Frederik
                  Not sure what OP means...?? πŸ˜•
                  It's fair that people need a little help now and then...
                  However, as Gilles have mentioned, mooarchi have set her SU level to Advanced, and such an easy model could easily have been made in a similar time as it took to post this thread...
                  I made my model in app. 10 minutes... If need be, I can make a quick tutorial, showing how easy it is to make... πŸ˜„
                  Cheers
                  Kim Frederik
                  • BoxB Offline
                    OP= Original Poster or Original Post depending on the context.
                    • gillesG Offline
                      gilles
                      What I meant was I can spent hours helping a newbie with a particular problem but a so basic shape for an advanced user...
                      • FrederikF Offline
                        Frederik
                        What annoyes me even more is, that I can see Susan has been online, but that she haven't even written a short THANK YOU...
                        It's happening far too often that users are asking for advice and help, but they never return, showing just a little gratitude... 😒
                        Cheers
                        Kim Frederik
                        • jeff hammondJ Offline
                          you guys scared her away from the sausage fest we have going on here πŸ˜’
                          πŸ˜†
                          @kim- nice looking model/render
                          • StinkieS Offline
                            Stinkie
                            That's not very surprising, given the, er, atmosphere. πŸ˜’
                            • FrederikF Offline
                              Frederik
                              Eehhh... You need to elaborate here, Tom... 😐
                              I don't see a bad atmosphere or anything, but even if the atmosphere was a little tense, I would still show my gratitude, if I had asked others for help... 😐
                              Cheers, Jeff... πŸ‘ πŸ˜„
                              Cheers
                              Kim Frederik
                              • JQLJ Offline
                                JQL
                                Hey Frederick,
                                Here's my gratitude! I just remembered a project where this will be perfect. It will take some time to finish, but some shelves will be fast to fill! Thanks and best regards,
                                JQL
                                www.casca.pt
                                • StinkieS Offline
                                  Stinkie
                                  Et cetera. Anyway, nice model, nice render.
                                  • JQLJ Offline
                                    JQL
                                    Well Tom that is definetelly true, however the post title and all the attitude related to it is justified IMHO.
                                    Title: Model 'Tea Tin' for Pay - wich implies someone needs a job well done and is willing to pay for it
                                    First post text: asking for help giving the subject and nicely put (though didn't mention payment conditions or specifying anything about payment)
                                    Replies: First of the responses was pretty amusing as an advanced user should be able to do this so fast that it really is wasted time to post here. As always in this forum there are several responses and then, someone with 20minutes spare time takes his time to help. I am absolutely sure that Frederick didn't even bother to read that there was payment involved at the title. Even if the job was simple enough, modeling, texturing, material and lighting really came out perfectly.
                                    Conclusion#1: No reply from the author, no thanks (I shouldn't even bother about talkinf of payment)
                                    Conclusion#2: The community (me actually) comes out with a simple yet excellent model for another project. Nothing is wasted here wich is great, but "here" exists because of willingful people that share and thank.
                                    www.casca.pt
                                    • gillesG Offline
                                      gilles
                                      If I must apologize to cool down the "er atmosphere", well I do sincerely.
                                      Have a good week end everybody. β˜€
                                      • ely862meE Offline
                                        ely862me
                                        As far as I see this she didn't asked anything for free. Sometimes there are requests like this but with more complicated things, and then people just say I have sent you a message or say nothing and send messages. Why would now be different ?
                                        It doesn't matter how simple things are if you don't have time to model them. This was a simple interview and I took the advantage and now I have done about a dozen of other models for her, and indeed she is busy.
                                        I hope you don't mind, do you ?
                                        Elisei (sketchupper)
                                        Come and See EliseiDesign
                                        • StinkieS Offline
                                          Stinkie
                                          Elisei, I'm not altogether sure what you're saying. Why would I mind?
                                          You have a nice weekend too, Gilles.
                                          • ely862meE Offline
                                            ely862me
                                            That last line was not addressed especially to you but to you all who felt they were not appreciated properly in this matter.
                                            I am actually happy that there are people who help more than me, without expecting something in return . But I am glad I judged this offer properly .
                                            I hope you don't mind I took this small job and I keep my client busy !
