    Any smokers here? Wanna quit?
    822 Posts 42 Posters 448.5k Views 42 Watching
    • olisheaO
      olishea
      @futurepast said:
      I was smoking 2 1/2 packs a day, and went with the 12 mg. The first flavor is English toffee. I am having to get used to it. It seems harsh. Unless I take really small hits it makes me couth my head off. Am I too high at 12 mg.? It doesn't seem so because I always seem to want more..
      The nicotine level does not affect harshness (or throat hit as we call it). 18mg may be better for you if you smoked 2.5 packs a day. 24mg may be a bit too high and make you feel dizzy.
      The liquid you are vaping will have a high PG ratio. For smooth vapour you need a liquid which has a higher VG ratio. High VG ratio also gives much bigger plumes of vapour.
      I recommend liquids with a 60/40 PG/VG mix or 50/50. I am currently vaping a 60/40 mix and loving it.
      100% PG liquids just make me cough and have little vapour production. Some people like this, although, it's not so common.
      You will find US liquids are smoother and have more vapour. Chinese liquids tend to be harsh with less vapour. It's because Chinese cigarettes are generally much harsher than US ones, so the e-liquid industry makes liquids according to the target market. This is just a general rule of thumb; the only way you'll know if the liquid is harsh or not is to find out before buying what the PG/VG ratio is.
      When you find a nice flavour with smooth vapour, you'll never look back. πŸ˜„
      oli
      • F
        Futurepast
        I suppose I need to go back to the shop and ask more questions about what they have. Because I haven't a clue about PV or what ever.....LOL
        • soloS
          The coil could be roasted causing a burning of juice hence the coughing also.
          • F
            Futurepast
            Ok so I did some "research". The liquid I bought is a 50/50. The smokes I were smoking were a "Light". The "burn" I am getting is about the same as when I would smoke a cig down to the butt. So if I go with a 40/60 that would make it smoother, or should I just wait and see if I get used to the 50/50?
            • GarethG
              Gareth
              Most of my liquids are 60/40 and 50/50 @ 18mg nicotine. The more expensive ones are very smooth, however, I bought some cheap eLiquids earlier on and they are not so pleasant on the throat (and the flavours aren't so good either)
              Try vaping at a lower voltage (if you have that option)
              I am becoming convinced that it is worth paying a little more to get good liquids which have a nice flavour and throat hit. Some of the Americans seem to do this very well. The Plume Room and GoodLife in particular, and to a slightly lesser extent Mt Baker)
              • olisheaO
                olishea
                Its noteworthy that liquids with impurities are also very harsh, they are usually cheap. Good advice Gareth.
                oli
                • olisheaO
                  olishea
                  Could also be the atomiser that is giving the burnt taste. EGOs do deteriorate quite quickly and occasionally I've had one that tastes terrible straight away.
                  Try a new atomiser head and a new brand liquid. 50/50 mix is generally very smooth. It's only when you start going to 80/20 PG/VG that you get a big throat hit. Remember its the PG that gives throat hit and VG gives large smooth plumes.
                  If you still don't have any success try an EVOD at least, it's a very popular atomiser and consistently smooth. The EGO is OK but strictly a beginner device which is actually quite infuriating at times as it's so inconsistent. I used one for a month or so before I upgraded.
                  Please don't be put off by this experience....sounds like you either have a dud device or liquid. πŸ˜„
                  oli
                  • soloS
                    That was my first opinion.
                    • olisheaO
                      olishea
                      Thanks for corroborating that Pete.
                      Might be an idea to just change the atomiser head first to eliminate what is causing the issue.
                      I doubt very much that a 50/50 liquid is too harsh. In fact, I find 50/50 almost too smooth so I have gone back up to 60/40 for a bit more throat hit.
                      Again, don't be put off I think you've just been a bit unlucky.
                      oli
                      • GarethG
                        Gareth
                        thought I'd better bump this topic before it moves to the next page
                        .....there are probably many smokers here in SketchUcation who haven't seen this topic and will miss out on the chance to experience being converted to wonderful world of Vaping...!
                        • Dan RathbunD
                          Dan Rathbun
                          Spoken like a true missionary!
                          Although vaping did not work for me (I gummed πŸ˜† ) ... it has been a full year since I quit cigs!
                          I do not miss the butts, ash, or the stink. I have a neighbor two doors down that smokes. When I walk pass his house it reeks of smoke from 75-80 feet out on the street! I used to be generating that kind of stink from our back porch. NO more!
                          I'm not here much anymore.
                          • olisheaO
                            olishea
                            Nice work Dan!
                            Yeah smoking absolutely stinks. Not just around your house but clothes, furniture, skin, hair, car etc....
                            Nearly a year smoke-free for me now.
                            I'm still on 12mg nicotine, will probably reduce when I get back from holiday.
                            Speaking of which.....does anyone know what the rules are regarding E-Cigs and travelling by air? Am I even allowed to take my E-Liquid into Switzerland?
                            I've got a feeling that several unmarked bottles in my main luggage might look suspicious, so should I juist buy some labelled pre-mixed liquids?
                            Last thing I want is to arrive in Switzerland with confiscated E-Liquid and E-Cigs!!! I am definitely not carrying anything in my hand luggage though, that's obvious.
                            oli
                            • GarethG
                              Gareth
                              Well done Dan.
                              I must admit I had no idea how bad my house, my car and me must have smelled while I was smoking.....and I don't miss the burn holes in my shirts and car seat I used to get occasionally when I smoked in the car..!
                              Hey Oli, try vaping on your flight and let us know what happened....!
                              • soloS
                                9 months cigarette free!!
                                • stefanqS
                                  stefanq
                                  Pete, I think you are 10 months, but who's counting! 😍
                                  • soloS
                                    πŸ’š 😳
                                    I had to use my fingers, you are right, April 3rd is a year.
                                    • olisheaO
                                      olishea
                                      http://sincemylastcigarette.com/banners/1362072600_20_1_GBP_7.25_dark.png
                                      I think that means 11 months for me! It was the very start of March I quit.
                                      Strange how the banner thing says 1 year, -1 month lol I guess that means 11 months haha
                                      GREAT work everyone! I bet you all feel much much better.
                                      oli
                                      • GarethG
                                        Gareth
                                        Feeling great indeed...
                                        ....have even take up a bit of casual cycling (I've done it more than once, so I guess that reinforces my commitment to 'recycling'...!) πŸ˜†
                                        • F
                                          Futurepast
                                          Well I still smoke about 3 cigarettes a day (weekdays). Mainly because, I can't hold the weight of even my small unit in my mouth and work at the same time πŸ˜† . We get into production runs and I can't stop to take a break, or my crew stops also! I tell them that "If you want lunch you better be able to have a hammer in one hand and a sandwich in the other" so I have to live to the same standards πŸ˜‰ But I have finally got my juice and unit(s) all working where I like. 40/60 24 mg at 4.0
                                          • olisheaO
                                            olishea
                                            Vape Porn!! I bought a cheap upgrade for my mother to congratulate her for being smoke-free for 12 months.
                                            I really like the Protank2. It's by no means comparable to a Kayfun in terms of flavour but it really is a great clearomiser. The Pyrex glass gives it a great quality finish. I also bought a Protank 2 for myself as a backup to the old faithful Kayfun.
                                            The SID is perfect for the price. Can't go wrong there! First device I've ever had with an OLED screen too!
                                            Here is the Smoktech SID with a Kanger Protank 2 on top. Sorry about poor photo quality, I just used a mobile.
                                            Happy Vaping guys!
                                            http://i654.photobucket.com/albums/uu269/olishea/IMAG0008_zps9dtrlura.jpg
                                            And here is the Protank 2 on top of the Provari Mini. It actually suits the Provari very well. I also placed the Kayfun on the SID just to show what it looks like.
                                            http://i654.photobucket.com/albums/uu269/olishea/IMAG0009_zpsugkqohek.jpg
                                            And finally my usual setup....Kayfun on either the Provari Mini or MVP V2. See how battered my Provari and Kayfun look after 12 months! :laugh: πŸ˜„ I have screwed the Protank 2 on the MVP in this photo just to show how it fits (very well).
                                            http://i654.photobucket.com/albums/uu269/olishea/IMAG0013_zpsy3p6brom.jpg
                                            oli
                                            • 24
                                            • 25
                                            • 26
                                            • 27
                                            • 28
                                            • 41
                                            • 42
                                            • 26 / 42
