    Dynamic Components reacting to Scene (aka Page) changes
    9 Posts 6 Posters 8.8k Views 6 Watching
    • snicoloS Offline
      snicolo
      Hi All,
      I just wrote a blogpost about Dynamic Components reacting to scene changes.
      You can find it at http://sketchupapi.blogspot.com/2009/07/dynamic-components-that-react-to-scene.html
      enjoy.
      Simone.
      Simone Nicolo
      QA Manager
      http://www.sketchup.com
      • Chris FullmerC Offline
        That's great, thanks Simone! I'll look it over when I get a chance, but it sounds quite interesting.
        • JClementsJ Offline
          JClements
          Here is an sample file that Simone created.
          After installing the script and opening SU and the .skp file, click on each scene to see what it looks like.
          Then add any geometry to the model and replay the scenes and observe what a scene then displays.
          I think you can see the possibilities for creating "triggers" to a model.
          Scenes.rb
          DC_trigger_ via_scenes.skp
            Phil Rader AIA
            That is cool. Thanks Simone
            http://www.philrader.com
              goga63
              the plugin works perfectly. But I would like to add the ability to input values for scene changes.
              I added code first :
              menu = UI.menu("PlugIns").add_item("Scenes") {
                prompts = ["looping scene ?  "]
                input = UI.inputbox prompts
                $sOptions_scenes=input
              you can now set the number of scenes in the cycle
              and changed the code:
              attributes[SCENE_TRIGGER] = (((attributes[SCENE_TRIGGER].to_i+1)%5)).to_s
              ...to this:
              scene_loop = [$sOptions_scenes].to_i
              attributes[SCENE_TRIGGER] = (((attributes[SCENE_TRIGGER].to_i+1)%scene_loop)).to_s
              unfortunately the last piece of code does not work
              Can someone suggest a solution ?
              Here's the entire code of the modified plugin:
              #useful constants
              # Copyright 2005-2008, Google, Inc.
              # Permission to use, copy, modify, and distribute this software for
              # any purpose and without fee is hereby granted, provided that the above
              # copyright notice appear in all copies.
              # THIS SOFTWARE IS PROVIDED "AS IS" AND WITHOUT ANY EXPRESS OR
              # IMPLIED WARRANTIES, INCLUDING, WITHOUT LIMITATION, THE IMPLIED
              # WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE.
              # This code snippets allows you to have Dynamic Components
              # that modify themselves based on a Scene Change
              # They need to have at the top level the following attributes
              # "scene_change" a boolean value that if true force the DC to react to scene changes
              # and if false has the DC ignore the scene change
              # and
              # "scene_trigger" which is the index that is incremented every time there is a scene change and
              # it is used to change attributes for the DC.
              # Attach our observer.
              # and
              # Author; Simone Nicolo
              require 'sketchup.rb'
              # Define the Frame Change Observer which is documented in the Pages class.
              class FrameChangeObserver
              def initialize
              # @current page is used to make sure that the observer is only triggered by page changes
              # This is to workaround the PC bug that does not correctly populate the fromPage variable in the
              # callback to frameChange.
              @current_page = Sketchup.active_model.pages.selected_page
              # Callback triggered by the Frame change observer.
              # fromPage is populated with the page we were coming from, toPage is
              # populated with the page we were transitioning to
              # and percent done contains the percentage of the transition that
              # has completed.
              def frameChange(fromPage, toPage, percent_done)
              # If there has been a page change and it has completed
              if (not toPage.nil? and percent_done == 1) then
              if @current_page != toPage then
              #update the current page
              @current_page = toPage
              #find the DCs that need redrawing, and redraw them.
              find_dc_for_redraw
              # This function finds all the DC's that need to be redrawn based on a scene transition and
              # on the boolean scene_change attribute if scene_change is true, change and redraw
              # the DC on a scene transition, if it is false do not change or redraw the DC.
              def find_dc_for_redraw
              entities_list = Sketchup.active_model.entities
              if entities_list != []
              # For all the entities in the model
              entities_list.each do |item|
              type = item.typename
              case type
              # Find the Dynamic Component instances
              when "ComponentInstance"
              if not item.attribute_dictionaries.nil?
              attributes = item.attribute_dictionaries[DICTIONARY_NAME]
              # If they have a scene_change attribute that contains true
              if (not attributes.nil? and attributes[SCENE_CHANGE] == 1.to_s)
              # Increment the scene_trigger attribute.
              # Here we are allowing the scene trigger attributes to only have the values
              # 1, 2, 3, and 4.
              if attributes[SCENE_TRIGGER] == "0" then
              attributes[SCENE_TRIGGER] = 1.to_s
              # Redraw the DC using the $dc_observers global variable.
              $dc_observers.get_latest_class.redraw_with_undo(item)
              else
              UI.messagebox("There are no entities in this model!")
              if not file_loaded? 'scenes.rb'
              # Useful constants
              # Dynamic Components dictionary name
              DICTIONARY_NAME = "dynamic_attributes"
              # Boolean attribute that turns on and off the reaction to a scene change for the DC
              SCENE_CHANGE = "scene_change"
              # Index attribute for the DC that is used to drive changes in the DC.
              SCENE_TRIGGER = "scene_trigger"
              # Attach the frame chage observer to the global Pages object.
              id = Sketchup;;Pages.add_frame_change_observer(FrameChangeObserver.new)
              file_loaded 'scenes.rb'
              • Dan RathbunD Offline
                Dan Rathbun
                (1) It is NOT a plugin, it is a code example.
                (2) It is NOT a very good example. (It was written long ago when Simone was new at Ruby.)
                Because:
                It defines plugin specific objects at the toplevel "main" instance of Object. This includes constants and classes.
                It needs to be totally overhauled. (I see at least 1 bug in it. entities_list != [] will always be true because it is not an Array (or subclass,) object.)
                Your modifications also violate community rules. Your creating a global var for use with only 1 plugin.
                Please explain more specifically what you want to change with an inputbox ?
                I'm not here much anymore.
                  goga63
                  Dan, thank you for taking the time to answer my question
                  In the source code in line :
                   # 1, 2, 3, and 4.
                  determined how many scenes will loop. I would like to change this setting without changing the code. For this I am trying to use the InputBox. Вut my knowledge is not enough. can you help me ?
                  P.S. Sorry for my English, I use Google translator
                    Dan Rathbun
                    The whole example STILL needs an overhaul... but for now:
                    💭 UI.inputbox returns an array of values, even if there is only 1 input item.
                    $sOptions_scenes[0]= "5"
                    $sOptions_scenes[1]= 5
                      input = UI.inputbox( prompts,[$sOptions_scenes[1]], "Enter Scenes" ) rescue [$sOptions_scenes[1]]
                      $sOptions_scenes[0]=input[0].to_s
                      $sOptions_scenes[1]=input[0]
                    and further down:
                    scene_loop = $sOptions_scenes[0].to_i
                    EDIT: DC redraws when the limit is reached, and trigger is reset to 0.
                      goga63
                      Dan , thanks for your help. I will study it.
