    šŸ”Œ Smart Spline | Fluid way to handle splines for furniture design and complex structures. Download
    Curved Staircases
    171 Posts 19 Posters 36.9k Views 19 Watching
      jabbers
      Garry,
      Initial testing of the beta plugin looks very encouraging. I am very confident that this plugin will help stair designers/manufacturers model there staircases quickly and efficiently, and best of all, can be edited in your dialogue boxes in matter of seconds. Looking forward to help develop this plugin to a invaluable tool..
      Regards BOB
      • KrisidiousK Offline
        Krisidious
        click center would be my preferred method. With the speed of your code I don't think there will be any issue with running in the current model.
        By: Kristoff Rand
          Krisidious
          Think we can get it to make newel posts like this?
          By: Kristoff Rand
            Garry K
            That is gorgeous! But unfortunately it is out of scope for this software.
            Jabbers has a 5 axis CNC - maybe he could do it !!!
              Garry K
              I've added the progressive flare to the plugin.
              This stair has a flare amount of 20 mm, and a progressive flare of 20 mm ( could have been different ) and a flare count of 5 treads.
              So starting at the bottom of the stair we have the following flares at the front of the treads in mm.
              1 - 120
              2 - 100
              3 - 80
              4 - 60
              5 - 40
              6 - 20
              7 - 20
              13 - 20
              I have also fixed a number of bugs - but before I can release a new version to the testers I've got this wild bug ( my inadequate testing let this one slip in ) OOPS !!!
              It happens with flare amounts of 80 mm or greater on housed stringers.
              Progressive flare
              80 mm flare with housed stringers
                Krisidious
                what do you think about a future feature of flaring of the stringer as well? to a have a 3' top of stair with a 4' or 5 ' bottom?
                By: Kristoff Rand
                  Garry K
                  It is possible for the future. Even a straight stair that flares both ways.
                  I'll add it to the wish list.
                    jabbers
                    I will second Kristoff's idea about flaring the strings also, also might be an idea to have a straightening of strings option as Garry said , say the first X no of steps, it would make it very handy, especially the wall/outside string.
                    BTW ..if any one wants to 3d model the horse newel. i will machine it...min order 50 peices !!! .
                    Regards BOB
                      Garry K
                      I've added a couple more stair configurations to StairMaker. An Open Riser choice and a Rail Style.
                      The input box is getting pretty tall and there are more options to come. Once the input box gets to big I will have to either split it up into 2 or more input boxes or I can go with a web dialog box where I have way more control.
                      Here is a the tall StairMaker input box and also a web dialog box. The web dialog box is my preferred way of doing things but there are advantages to each.
                      web dialog box:
                      1. It is easy to organize the inputs into various sections
                      2. You can have check boxes and radio boxes
                      3. Unfortunately there isn't an easy way to allow a mix of inputs - some metric and some imperial.
                      4. At this stage I would only support decimal inputs for only metric or only imperial. No fractions
                      Sketchup input box
                      1. A lot less coding using the built in input box.
                      2. You can mix inputs by using mm or "
                      3. you can use fractions for imperial
                      4. At some point the input box will become too large and will have to be broken into several inputs.
                      What do you guys think? Do you like the web dialog or the built in Sketchup Input Box?
                      I'd love to have a vote on this - but I don't know how to set that up.
                      Built in Sketchup imput box
                      Web dialog input box
                        A little video will be very appetizing! ā˜€
                        • F Offline
                          Futurepast
                          I think the Sketchup input would do, just make drop downs of each category off the main screen Treads, Stringers, Railings, etc. šŸ˜„
                            Garry K
                            I have considered that as a possible solution; however, it would be beneficial to have all the configurations on one form - thus the web dialog.
                            I have now built the parsing and conversion routines and have found a bug in Sketchup's conversion routines. This also affects Sketchup's input box when inputing fractional inches such as '2 1/2"' and using a model setup in millimeters.
                            http://sketchucation.com/forums/viewtopic.php?f=180%26amp;t=55722
                            I have a fix that works with the web dialog box.
                              Garry K
                              I've got the web dialog working with the Stair Maker. I have also solved a few of the cons of using it. Since I needed a web dialog anyway - this seems like the best route.
                              You can use fractional inputs and you can use mixed inputs. Furthermore, I may be able to leave the web dialog box up while the stair is drawing. The advantage of this is you would be able to make changes and have the stair redraw itself ( remove the existing one and create a new one ) each time you click 'OK' providing that web dialog box hasn't closed. Once the web dialog box is closed then we could move on to a second curved stair without messing with the first one.
                              Another advantage is that I can fairly easily add in an expression evaluator. I am use to this feature in various CAD systems. For instance - you can type in 1000 - 27.3 for width and it would replace what you type with 972.7
                              The built in Sketchup input box has limitations that aren't there with a dialog box. It would be very easy to add in additional pages that could be used to store user defaults.
                              completed web_dialog
                              • charly2008C Offline
                                charly2008
                                web dialog box
                                šŸ‘ šŸ‘ šŸ‘ šŸ˜„ šŸ˜„ šŸ˜„ šŸ˜„
                                  Krisidious
                                  I like the side by side too... the length was a little much.
                                  By: Kristoff Rand
                                    Garry K
                                    Thanks guys. Another neat thing about the web dialog is I can add a bit of mouse over help on some of the prompts and or input fields.
                                    For instance a few of the prompts that need help are:
                                    'Radius'
                                    'Set to 0 and StairMaker will calculate based on degrees and Average Run'
                                    'Degrees'
                                    'Average Run'
                                    'Average Run is ignored if both Radius and Degrees are set'
                                      Garry K
                                      I have a StairMaker plugin that is ready to go. This is version 1.0.3.
                                      You may go to my web site CabMaker32.com, register and download the plugin.
                                      The plugin is a zip file - unzip it to your plugins folder. There should be 1 file added to the plugins folder GKWare_StairMaker_Ext.rb and a folder called GKWare.
                                      Please edit file GKWare/StairMaker/defaults.txt.
                                      You will need to put in your userid and password that you received via the register process.
                                        Garry K
                                        Pilou Here is the video that you requested.
                                          Garry K
                                          I am interested in finding individuals who would like to test this plugin.
                                          Specifically I'd like to know if it even works with Mac.
                                          Is anyone experiencing any problems with the plugin.
                                          Does anyone have any suggestions?
                                            Krisidious
                                            I'm on PC but no issues here.
                                            By: Kristoff Rand
                                            • 6 / 9
