    Paste between instances and onLayerAdded issue
    8 Posts 4 Posters 628 Views 4 Watching
    • jiminy-billy-bobJ
      jiminy-billy-bob
      Hi guys
      I've come across an annoying issue with layersObservers.
      I have a layersObserver doing stuff when a new layer is added. The operations are wrapped in start_ and commit_operation, and I use a timer to avoid doing stuff right inside the observer (TT's advice), like this :
      <span class="syntaxdefault">module Test<br /><br />    class TEST_layersObserver </span><span class="syntaxkeyword"><</span><span class="syntaxdefault"> Sketchup</span><span class="syntaxkeyword">;;</span><span class="syntaxdefault">LayersObserver<br /><br />        def onLayerAdded</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">layers</span><span class="syntaxkeyword">,</span><span class="syntaxdefault"> layer</span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">            timer </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> UI</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">start_timer</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">0</span><span class="syntaxkeyword">,</span><span class="syntaxdefault"> false</span><span class="syntaxkeyword">)</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">{<br /></span><span class="syntaxdefault">                UI</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">stop_timer</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">timer</span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">                Sketchup</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">active_model</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">start_operation</span><span class="syntaxkeyword">(</span><span class="syntaxstring">"Add layer"</span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">                    </span><span class="syntaxcomment">#some code<br /></span><span class="syntaxdefault">                Sketchup</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">active_model</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">commit_operation<br />            </span><span class="syntaxkeyword">}<br /></span><span class="syntaxdefault">        end</span><span class="syntaxcomment">#def<br /></span><span class="syntaxdefault">        <br />    end</span><span class="syntaxcomment">#class<br /></span><span class="syntaxdefault">    <br />    Sketchup</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">active_model</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">layers</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">add_observer</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">TEST_layersObserver</span><span class="syntaxkeyword">.new)<br /><br /></span><span class="syntaxdefault">end</span><span class="syntaxcomment">#module  &nbsp;</span><span class="syntaxdefault"></span>
      No issue when adding a new layer manually or via ruby, but when I try to copy some geometry from another instance of SU, being on a layer that is not already existing in the new file (The one where I want to paste), it fails.
      When pasting, SU tries to add the non-existing layer (sometimes I even see it flashing in the layers window), and goes right back to the previous tool. No layer added, no geometry added.
      It works fine without a timer, or without start/commit.
      You can try the snippet above, it fails. (If you have Layers Panel installed, disable it beforehand)
      This is really frustrating... 😒
        MSP_Greg
        Have you tried pasting with only one new layer?
        I just checked in my code, and as you probably know, onLayerAdded is called for each new layer. This may be causing issues because you may have more than one start_operation beginning but not yet commited as the multiple calls to onLayerAdded are made.
        I'd try puts statements inside onLayerAdded and also inside start_operation and see if that's the issue.
        Greg
        • Dan RathbunD
          Dan Rathbun
          Layers can also be added when a user inserts a component from their library or the 3D-Warehouse.
          I'm not here much anymore.
          • Dan RathbunD
            Dan Rathbun
            FYI... Test is a standard Ruby module, into which the SU Dev Team added a set of undocumented test methods.
            Suggest you nest YOUR "Test" module inside YOUR toplevel namespace.
            ie:
            module JBB
              module Test
                # code
            • jiminy-billy-bobJ
              jiminy-billy-bob
              This happens with only one layer (Actually I haven't tested with multiple)
              And of course, I test this in my own namespace, I added "Test" only to post the snippet here.
              • jiminy-billy-bobJ
                jiminy-billy-bob
                Nervermind, it works when I put the timer inside the start/commit_operation... 😒
                • tt_suT
                  tt_su
                  That operation should be transparent...
                  • jiminy-billy-bobJ
                    jiminy-billy-bob
                    It is in my code. I just simplified everything to paste this snippet.
