    Baseball Stadium
    21 Posts 2 Posters 3.4k Views 2 Watching
    • BoxB
      All I can say is, get back to the the batting cage until your swing is natural, then batter's up.
      I should point out here that all my knowledge of baseball is from films, mostly bad.
      • C
        Coach_Travis
        I think I got the hang of the grouping / making a separate model. I can edit this model and just paste it back into my main model when I am finished. I think this will really help.
        • BoxB
          Better than that, you can "reload" a component.
          So if you have edited your saved component in a separate file you can open your main file and simply Reload the component and any changes you made will update in the main file.
          • C
            Coach_Travis
            How do you go about saving a component as its own file?
            • C
              Coach_Travis
              Disregard. All I had to do was right click and "Save As". It is always the easy things that trip you up. 😎
              • BoxB
                I figured if you called yourself Coach then you understood the concept of throwing a hint to help someone learn.
                • C
                  Coach_Travis
                  Yeah, you are really assisting me. It is so much easier to edit it as a component and just reload it. I am having problems with something that you might be able to assist with. The dirt "box" around the pitcher's mounds seem to be off plane with the slope of the dirt. I can no figure out what I did wrong. Do you see anything, or is it just the program?
                  Bullpen Comp.skp
                  • BoxB
                    You need to model clean and careful, and understand how layers and materials and textures work.
                    You seem to have created geometry on a layer that isn't layer0, never ever ever do this.
                    All Geometry is layer 0, I have yet to work out why it is possible t create it elsewhere but it is. Make raw geometry on layer0 and then once made into a group or component you can move it to or assign it to a layer. Layers are only a way to turn visibility on and off.
                    Use the kiss method until you understand where you want to go.
                    In this case, layers and materials may have hidden your problem. You think you have joined at the corner but from my quick look it seems you have missed.
                    If your problem is elsewhere I will look tomorrow.
                    • C
                      Coach_Travis
                      Box - Thank you. I have no idea why I added a layer, I must have accidentally pressed it. I will see what I can do.
                      • C
                        Coach_Travis
                        Box - I deleted the other layer and had everything transferred to Layer0. However, it still seems like there is something wrong with the dirt box around the pitcher's plate.
                        Bullpen Comp.skp
                        • BoxB
                          II don't know what you mean by something wrong, can you be more specific.
                          • C
                            Coach_Travis
                            I think it has to do with the program and pixilation. When I took a screenshot it did not show it.
                            • C
                              Coach_Travis
                              Here are some photos of my bullpen updates. Couldn't have done this without Box's help.
