    Reading SKP thumbnail
    7 Posts 3 Posters 411 Views 3 Watching
      tomasz
      I have made a search but haven't found a solution yet.
      Does someone know a way to read a thumbnail stored in SKP file?
      If SU Team could give us info on where we can find its location and a size, that would be enough πŸ˜„
      Tomasz
      Author of [Thea Render for SketchUp](http://www.thearender.com/sketchup)
      • Dan RathbunD Offline
        Dan Rathbun
        I also thought that tbd wrote a thumbnail extract utility, a long time ago.
        I'm not here much anymore.
          Dan Rathbun
          IF SketchUp is loaded, you can generate an image file for any skp file using:
          Sketchup::save_thumbnail
          If not, the thumbnail should be in the normal place and size required by Windows, so popular graphic utilities (like ImageMajik,) or C function calls can retrieve it.
          Checking the code snippets index, we have:
          [ cod e] extract png thumbnail image from .skp file
          ... which has both outside and inside SketchUp examples.
          πŸ’­
            tomasz
            Thanks! I have checked 3 or more pages with search result, but didn't find the snippets post. I will be checking it first now.
            I want extract them directly from files, without opening them in SU.
            Jim's extract_png.rb looks like a good solution.
              Dan Rathbun
              You do not need to open the file(s) using:
              .. just that you must use it from within SketchUp Ruby.
                tomasz
                Right, I didn't realize that there is a path parameter in this method!
                • tt_suT Offline
                  tt_su
                  blink -- me neither! I guess I always just skipped over that method...
