    Remove_observer bug?
    3 Posts 2 Posters 487 Views 2 Watching
    • fuzzybroF
      fuzzybro
      I have found following strange behaviour:
      I have one EntitiesObserver object and multiple definitions which are bound to the very same EntitiesObserver:
        observer = MyEntitiesObserver.new
        Sketchup;;active_model.definitions.each do |definition|
          definition.entities.add_observer observer
      and it works OK.
      But when I try to remove observer from the entities I'm able to remove it only from the first definition in the list. Other definition.entities.remove_observer(observer) are giving me the 'false' result and entities are still being observed by this observer.
      How do I properly unobserve multiple objects pointing to a single observer?
      OctaneRender for SketchUp Overview and Demo Version
      Latest updates, tutorials and artwork
      facebook.com/octane4sketchup
      • Dan RathbunD
        Dan Rathbun
        Is that code in a file that you are loading ?
        The local reference observer will be invalid after the file is done loading.
        I'm not here much anymore.
        • fuzzybroF
          fuzzybro
          It's a pseudo-code. The actual code implies that observer object is a class instance variable:
          class Scene
            attr_accessor(;observer)
            def initialize
              @observer = MyEntitiesObserver.new
            def observe
                definition.entities.add_observer @observer
            def unobservre
                definition.entities.remove_observer @observer
