    Spot Elevation Markers Plugin - Dev Help/Review
    21 Posts 8 Posters 4.3k Views 8 Watching
    • Dan RathbunD Offline
      Dan Rathbun
      FYI we have discussed in the past the Feature Request of adding Datum Dimensioning into SketchUp... as well as the issue that NONE of the dimension features of SketchUp are exposed by the Ruby API.
      The Marker would be similar to the native Sketchup::Text leader objects (callouts) which are also lacking some extended API features, such as specifying dynamic replaceable parameters for the leader text. Ex: If you attach a callout to a point, it shows all 3 (x, y, z) values in model units. BUT .. when moved the text does not appear to get automatically updated.
      So IMHO your plugin would be much easier.. if some of the issues with the API that we have already logged, were to be fixed.
      Display: No problem there if you put the markers on a spacial layer. Toggle that layer to control display.
      I'm not here much anymore.
        matt.gordon320
        Hi Dan! Thanks for your input. Let me ask you this based on your knowledge of the API. Do you think this is a decent project to move forward with given the lack of extended documentation in the API and my relative lack of experience? Or would you recommend a different project (perhaps a simpler script), at least until the API is updated?
        As I've said before, I'm all up for a challenge, but giving myself an insurmountably difficult task due to lacking API references sounds more like and exercise in frustration.
          Dan Rathbun
          Well in my "Newbie's Guide" I always suggest starting with a simple project first, learn the basics, and move on to more complex projects, step by step.
          Now another possibilty to work around the issues in the current API, may be to create your OWN dynamic component elevation callouts.
          These may only need the very basics of a plugin (menu items or toolbar buttons to insert them.)
          So first task, learn in "goodies" of Dynamic Components. You can have Text objects nested inside a DC.
          Part of the plugin code, could search for all DC named "ElevationMarker" and modify the text of their nested Text object to the current z value. (If you cannot get the DC to do it automatically.)
          Check the DC forum.
            matt.gordon320
            Thanks Dan! I've been fiddling with DC's for a little bit, and I see what you mean. Already I can get a DC that will update it's Z-height when moved. The next bit will be, as you said, searching and updating all the text within each marker. Thanks for the kick start...I'm sure I'll have more questions ๐Ÿ˜„
              Dan Rathbun
              The fastest way to get a collection of a CERTAIN component's instances, is to go through the model's DefintionList collection, rather than iterate through the model's Entities collection, which can be anything, ... primitives, groups, etc.
              compname = 'ElevationMarker'
              model = Sketchup.active_model
              list = model.definitions
              found = list.find {|d| d.name == compname }
              # found will be nil (& eval as false) if not found
              if found
                found.instances.each {|i|
                  # update the instance i here
              else
                # do something else here, if needed
                Ah! I've gotten all about this thread! (Just adding a comment now to ensure it appear on my list of threads I participate in.)
                  matt.gordon320
                  Hey guys,
                  Thanks for all the help so far. I'm going through and writing out a series of steps I need to take, so as to get the basics down first and not bite off more than I can chew (at least not more than I have already) ๐Ÿ˜† So I've got this question for you. Would it be faster and smarter performance-wise to create the Spot Elevation Marker Component "on the fly" as it were, in the script itself, or to include a folder with the script and have it simply import pre-made Spot Elevation Marker Components?
                  I figure the latter might be nice because, theoretically, I could add different types of markers in the future without having to constantly re-vamp the code every time. I don't know if this is a smart way to go though, as I don't know enough yet ๐Ÿ˜ณ
                  PS - Any refernces you guys have as to the Dynamic Components API? I haven't really found a lot yet on adding DC functionality through ruby, but then I probably haven't searched enough yet. I'll likely find it as soon as I submit this comment.
                  • O Offline
                    oslocadiz
                    Hi anyone,
                    I'm having problems installing the Spot Elevation Marker plugin. Could you please give me a little explanation where you have to place the plugin or how to install it?
                    Thank you in advance
                    • mitcorbM Offline
                      mitcorb
                      @oslocadiz:
                      As far as I can tell, this script is not ready for distribution. You might contact the author.
                      Another possibility would be one of TIG's tools with "Datum" as a keyword.
                      • O Offline
                        oslocadiz
                        @mitcorb
                        Thank you very much for the advice ๐Ÿ˜„
                          matt.gordon320
                          @mitcorb oslocadiz is correct, the script is not at a point where it's useful in any way. I'm just in the first stages of learning Ruby, so this post was more as a way of asking the skilled developers in the forum for advice and feedback, not as a usable script at this point.
                          Furthermore, TIG's produced (as usual) a very capable script that does Datum measurements, I'd recommend that. I may shelf this project for the time being anyway, as it's a little to ambitious for my knowledge at the moment. I wish I knew more, but I just haven't had the time to devote to it enough, or enough understanding at this point.
                          Thanks for the interest,
                          Matt
