    Mixed Up Data
    8 Posts 4 Posters 492 Views 4 Watching
    • s_k_e_t_c_h_yS Offline
      s_k_e_t_c_h_y
      I'm hoping this post works on the principle of 'as soon as I write it down, I work it out'. I have a class that upon being ran create lots of objects (great). If I move the first objects out of the way and run the program again with different settings the output of the second run is the output of the first run PLUS the second run on top of each other!
       If I select all of the objects (CTRL-A) and delete them after run 1 and then run again the same thing happens. Each run of my class seems to sit on the prior run? I assume I'm doing something bad with the namespace or some such.
       The project is quite long so it isn't easy to post snippets..
      Ideas...?
      Paul.
      • jolranJ Offline
        jolran
        It sounds like your output is an @varible not being set to nil at start of the program.
        It will store the values in @variable during the Sketchup session.
        Talking @variables in your module scope here, but since you say your having problem with a Class this might not be it.
          s_k_e_t_c_h_y
          Hmm,
          I'm not sure I do that? Here is a cut-down version of what I'm doing. Hopefully I'm not breaking too many good practice rules, but please let me know.
          Basically I have a lot of class variables (all the @@xyz) which have defaults, but get overridden after the HTML configure() has been ran. When configure() is complete is calls draw() then statistics() to implement the customized design in SketchUp. I use blocking threads to initialize these so that the configure has been finished().
          All of my shapes from draw() get pushed into @@geodesic which is a group so that all sub-shapes from the draw are bound together at the end.
          Insight appreciated...
          # Add a menu item to launch our plug-in.
          UI.menu("PlugIns").add_item("Draw Geodesic") {
            #Instantiate and configure the Geodesic
            geo = Geodesic.new
            geo.configure()
          class Geodesic
          	#Main Configuration items
          	@@g_frequency = 3
          	@@g_radius = 150
          	@@g_platonic_solid = 20
          	@@g_fraction = 0.6
          	@@g_center = Geom;;Point3d.new ([0, 0, -@@g_radius + 2 * @@g_radius * @@g_fraction])
          	@@draw_primitive_solid_faces = 0
          	@@primitive_face_material = [rand(255), rand(255), rand(255)]
          	@@draw_tesselated_faces = 0
          	@@tesselated_face_material = [rand(255), rand(255), rand(255)]
          	#Metal hub configuration
          	@@draw_metal_hubs = 1
          	@@metal_hub_outer_radius = 2.25
          	@@metal_hub_outer_thickness = 0.25
          	@@metal_hub_depth_depth = 4
          	#Wood strut configuration
          	@@draw_wood_struts = 1
          	@@wood_strut_dist_from_hub = 3
          	@@wood_strut_thickness = 1.5
          	@@wood_strut_depth = 3.5
          	@@wood_strut_material = Sketchup;;Color.new(255,215,0)
          	#Wood frame configuration
          	@@draw_wood_frame = 1
          	@@frame_separation = 12
          	#Dome reference data is stored in these arrays
          	@@geodesic = Sketchup.active_model.entities.add_group		#Main object everything contributes to
          	@@primitive_points = []
          	@@strut_points = []
          	@@triangle_points = []
          	#Dome shape data is stored in these arrays
          	@@strut_hubs = []
          	@@struts = []
          	@@frame_struts = []
          	#tolerance factor to circumvent small number errors
          	@@g_tolerance = 0.5
          	#HTML pop-up menu to configure and create the Geodesic Dome
          	def configure
                     # ... code ...
          	def draw
                     # ... code ...
          	def statistics
                     # ... code ...
                  private
                  #lots of support functions here
          SIncerely, Paul.
            s_k_e_t_c_h_y
            Hmmm,
            on further reading i appears I misunderstood @@var class variables. Now to correct the whole class....?
            • jolranJ Offline
              jolran
              You are not forced to use classvariables just because your in a Class πŸ˜„
              I think Ruby Monk has some nice and easy reading about this:
              http://rubymonk.com/learning/books/4-ruby-primer-ascent/chapters/45-more-classes/lessons/113-class-variables
              It says :"class variables can be used to store data that belongs to a class, but not to its instances"
                slbaumgartner
                @s_k_e_t_c_h_y said:
                Hmm,
                >   geo = Geodesic.new
                >   geo.configure()
                > class Geodesic
                > 	@@g_frequency = 3
                > 	@@g_radius = 150
                > 	@@g_fraction = 0.6
                > 	@@strut_points = []
                > 	@@strut_hubs = []
                > 	@@struts = []
                > 	@@frame_struts = []
                > 	@@g_tolerance = 0.5
                > 	def configure
                >            # ... code ...
                >         end
                > 	def draw
                >            # ... code ...
                >         end
                > 	def statistics
                >            # ... code ...
                >         end
                >         private
                SIncerely, Paul.
                Presumably you build your data in the various arrays @@primitive_points, @@strut_points, @@triangle_points, @@strut_hubs, @@struts, @@frame_struts by appending elements to the arrays. Do you clear out these arrays at the start of configure or draw? If not, because they are class variables the values will continue to accumulate until you close and restart SketchUp.
                • Dan RathbunD Offline
                  Dan Rathbun
                  This is true.
                  ANY or ALL instances of a class (or of a subclass of the class,) can access and change those class variables!
                  The easiest thing to do is search & replace @@ to @ so as making them instance variables.
                  Also your custom class should be within your OWN author module namespace.
                  I'm not here much anymore.
                    s_k_e_t_c_h_y
                    Fixed.
                    Thanks Dan for the reminder for the namespace. Namespace now implemented =-P.
