    Concatenate a string and an integer?
    4 Posts 3 Posters 670 Views 3 Watching
      tomot
      Does Ruby have this ability? It appear to me it does not, unless my search and coding is in error.
      For example:
      opposite=4; adjacent=3; angle=Math.atan(4/3).radians
      45.0
      string=".degrees"
      .degrees
      angle1=angle+string
      Error: #<TypeError: (eval):4542:in `+': String can't be coerced into Float>
      (eval):4542
      (eval):4542
      FYI: Autolisp: can concatenate a string and an integer: such that
      angle1=angle+string
      45.degrees
      [my plugins](http://thingsvirtual.blogspot.ca/)
      tomot
        Aerilius
        In ruby objects have a certain type and you can rely on that the type does not magically change on its own.
        For a number, the + method is defined to accept another number as argument and returns a number (that you don't want).
        For a string, the + concatenates strings and returns the resulting string, so you have to convert any object into a string first.
        There are many ways to create strings:
        string concatenation:
        90.to_s + " degrees" # slow because it creates a new third string object
        string appending:
        90.to_s << " degrees" # faster because it adds the second string into the first
        string interpolation:
        "#{90} degrees"
          tomot
          thanks for the explanation Aerilius: πŸŽ‰
          45.0
          string=".degrees"
          .degrees
          angle1=angle.to_s << ".degrees"
          45.0.degrees
          Its also great news because it finally allows me to make the acceptable 45.0.degrees substitution into the Sine Law that TIG was so kind to put into Ruby form.
          http://sketchucation.com/forums/viewtopic.php?f=180&t=53118
          tomot
            string appending:
            "#{90} degrees"
            Note that string interpolation is the fastest. (And reads easier IMO)
