    How to change the density of the emitters?
    15 Posts 5 Posters 6.1k Views 5 Watching
      sofie9536
      hi,it's just a density of several combined groups. i think so
        sofie9536
        Hi Anton, very thanks, but not works for me. i change the file, sk works not correct (SP7)
          Anton_S
          @javisomm said:
          but as I can not edit the density of emitters
          Yup, SketchyPhysics emitter function does not set density.
          Here is the new SketchyPhysicsTool.rb for SP3.2 which makes minor fixes and improvements to SP simulation.
          Copy to ...\Google SketchUp [n]\Plugins\SketchyPhysics3\ and click yes to replace
          [attachment=0:1tdn0e75]<!-- ia0 -->ControllerCommands.rb<!-- ia0 -->[/attachment:1tdn0e75]
          Now, you won't have to reduce the density of the boat; just increase the density of the ball you're emitting. πŸ˜‰
            Anton_S
            Oops, forgot to add ControllerCommands.rb. Now, it must work ❗
              Javisomm
              Thank you very much, it worked πŸ˜„ , then when you finish the ship and its sinking, I will do a video and I'll show πŸ˜„
                sofie9536
                thanks Anton, now it works
                  Anton_S
                  Great πŸ‘
                  I'll probably do more improvements and fixes, until CPhillips (the creator of SketchyPhysics) releases a new version.
                    sofie9536
                    I wait for the new version, it's a holiday for me 😍
                      mptak
                      Anton: hooray for you. Can you give a quick rundown on what you have or will be doing? I will also try to experiment with what you released above but a short rundown would be greatly appreciated.
                        Anton_S
                        In progress, I didn't done much there. The original focus was to improve SP error handlers. In original version when you got an ontstart error, it displayed a huge messagebox lacking the exact info. The new error handlers are much better. They give you the info you need:
                        • Stating exact callback property, like if error comes from onpostframe, it says 'OnPostFrame Error...'
                        • the error
                        • line number
                        • group entity from which the error comes from
                        • the error is posted in both the messagebox and ruby console
                        Features:
                        • Added FPS to the status text
                        • My own ViewportDrawing Utility which modifies the model bounds to avoid being clipped
                        • Added cursorPos function, which returns [x,y] cursor position relative to Viewport origin.
                        I'll make a documentation of all SP function once I'll clean it up a little.
                        My aim: First - clean-up and fix bugs. Later - we'll see.
                          sofie9536
                          hi Anton, with the 2 new files will no longer run my twilight render engine (animation rendering). ? please help
                            sofie9536
                            I installed the old files back, thanks anyway anton πŸ˜„
                            • ashscottA
                              ashscott
                              Anton, you wrote Sketchyphysicstools.rb and controllercomands.rb yourself?
                              Have you posted these in a separate thread so everyone can benefit from them?
                              Fantastic work, I'm really impressed
                              Ash
                              Just some stuff I do with Sketchup.
                                Anton_S
                                No, just modified them.
                                Well, those files don't do much; they don't fix SU2013 crash, and in fact there are much more improvements and bug fixes to be made, including those are not the only files that require optimizations. Fixing them would require re-uploading the whole SketchyPhysics.
                                I'm also not sure if I have the right to mess into this project. I can work on a unofficial release, but I think CPhillips will update it soon. So, making more changes wouldn't be necessary.
