    Why is 2013 breaking this plugin?
    4 Posts 4 Posters 510 Views 4 Watching
      doernbrackc
      I wrote a very simple plugin for SketchUp 8 which no longer seems to work with 2013. Is there something different or new that I need to add into the ruby code? Below is my simple code which takes every line in an Autocad file and breaks out the end points. Nothing complicated.
      require "sketchup.rb"
      module CD
      def self.export_points
      model = Sketchup.active_model
      ents = model.active_entities
      path = UI.openpanel()
      if not path then return end
      aFile = File.new(path, "w")
      ents.each{|e|
      if e.is_a?(Sketchup;;Edge)
      sp = e.start		 #starting point of the line
      ep = e.end		 #ending point of the line
      x1 = sp.position.x
      y1 = sp.position.y
      x2 = ep.position.x
      y2 = ep.position.y
      aFile.puts(x1.to_s().chop + " " + y1.to_s().chop)
      aFile.puts(x2.to_s().chop + " " + y2.to_s().chop)
      aFile.puts(" ")
      aFile.close()
      UI.messagebox('Script Complete')
      end # CD.export_points
      end # MODULE
      filename = File.basename(__FILE__)
        if not file_loaded?(filename)
        UI.menu("Plugins").add_item("ExportWalls") {CD.export_points}
        file_loaded(filename)
      • Chris FullmerC
        What kind of errors do you get in the ruby console?
          driven
          hi
          it works on my mac...
          you need to fill in your details, so we know what os etc... your using.
          also use a code block to add your code to the message.
          you may be having permission issues, but I don't even know which platform your using.
            What is breaking? What is expected behaviour?
