    Save Model using Ruby API on Windows
    7 Posts 4 Posters 1.0k Views 4 Watching
    • C
      Conchords
      I'm having some problems saving a model using the ruby api on windows, but the code seems to work on mac. When I call model.save and then check if it's modified it says it isn't, as if the model was saved. But when I restart sketchup and open the model the changes aren't there.
      Has anyone run into this?
      • Chris FullmerC
        What are the errors being output to the ruby console?
        • C
          Conchords
          there aren't any errors. I've had it throw errors on invalid paths in the past but it isn't doing that anymore. I also don't think that it's saving to a completely different path because it works on the mac version.
          • renderizaR
            renderiza
            The following code I found here... https://groups.google.com/forum/#!msg/sketchupruby/ymKyqD_nxBU/AczVTLjFld4J
            # Description;
            #        sketchup's "model.save" does not work.
            #        routine to save a .skp file with the same name as the current model
            #         need to save file with a temporary name, (close model ?),
            #         then move the temporary name to the real name
            def model_save(sfile)
                sfile2 = sfile + '.tmp'
                bret = Sketchup.active_model.save(sfile2)
                return(bret) if !bret
                # now move sfile2 to sfile
                # remove existing file
                # need to close existing model first
                Sketchup.file_new
                if File.exists?(sfile)
                    begin
                        File.unlink(sfile)
                    rescue
                        warn "Could not delete file; " + sfile
                        return(false)
                bret2 = File.rename(sfile2, sfile)
                printf("INFO; Saved to \"%s\"\n", sfile)
            [url=https://www.sketchupcode.com/:z3kqsidd]My Extensions ...[/url:z3kqsidd]
            • Chris FullmerC
              From that same thread, Dan mentions you can use this command to simulate the actual File > Save:
              Sketchup.send_action( 57603 )
              Then you could use the regular Model.save for Mac and the send_action for PC's. I've not tried it, but it might be a solution.
              • C
                Conchords
                That worked great, thanks.
                • Dan RathbunD
                  Dan Rathbun
                  Actually at that time I did not know of the cross-platform send action string, "saveDocument:" ...
                  ... so you can just use Sketchup.send_action( "saveDocument:" )
                  I'm not here much anymore.
