    [Plugin] SPGears
    93 Posts 41 Posters 197.9k Views 41 Watching
      jgrundman
      @sdmitch said:
      ...what parameter values did you enter to achieve the various gears?
      For the larger diameter samples, I used the default 10" radius and the smaller ones are between 5" and 7" radius (don't recall, exactly). The beveled and flat gears are different bevel angles of 45 and 90 degrees, respectively. The helicals are all 30 degrees, except the mate to the long pair which is -30 degrees. The bevel can be set to negative values, putting the teeth on the interior, but the results are less than satisfactory. I will be adding true "internal" gears in version 2. I also need to redo the beveled helical since the current params result in a semi-hypoid shape.
      • B
        bheffernan
        Thanks for this plugin. I'm a longtime user of gear.3.rb and this looks like an upgrade.
        Addition of worm gear function would be great. I'm struggling with getting a parametric worm gear in sketchup which I use to export to .stl and print on a 3D printer for various projects. The hard part (as discussed in this thingiverse model: http://www.thingiverse.com/thing:9827) is the worm gear part.
        Anyway, thanks again,
        Brendan
        • T
          Trogluddite
          Hi Again,
          Just a little follow up on that old bug report.
          The IT guys finally got my new machine set up - and, oh no, the plugin was still having problems...
          ...until I went into the BIOS and increased MoBo GPU RAM to 500MB instead of the paltry 32MB allocated by default (had to use the MoBo, as the supposedly nice graphics card they put in couldn't even handle the SU view port!).
          It now strikes me that this might have been the problem with the old PC - that also was using the MoBo graphics, and can't have have 500MB GPU space because the whole machine only had 1GB installed!
          Here's a piccy of the first completed project...
          ...suffice to say, the boss was well pleased, especially as upcoming projects will require much more complex gear trains than this.
          Many thanks for your excellent tool,
          Trog
            sofie9536
            Thank you, the gears are perfect for use in sketchyphysics
              mikaelgu
              First of all a huge thank you!
              I've been looking for a way to have custom gears made for a while until I found this plugin. Decided to try it out by drawing a pair of helical beveled gears and had them 3d-printed. As far as I can tell, the gears mesh beautifully and work axactly as they should!
              I just have one small wish: It would be great if the center guide that is created for the (bevel) gears would extend all the way to tip of the pitch cone. It would speed up aligning the gears in sketchup significantly.
              • T
                tulacong
                oh my god thank you
                  mikaelgu
                  Found a small bug:
                  Regardless of the unit of measure of pitch radius, the face width is always measured in inches, makes it a little harder to make gears of certain widths when using the metric system.
                    2Tricky
                    I am brand new to this Plugin and Sketchup. I had no problems in principle with this plugin - I'm using Win 7. My aim is to create gcode and so far I have played with the plugin gear.3.rb to make the gears and the Phlatboyz plugin for gcode. However, I was dissapointed to find that gear.3.rb uses all straightline segments which to cut a long story short, makes the code too long for our mill. I was hoping for arcs in this plugin but it too uses straight lines. I'd love arcs to be a feature of this plugin.
                    Cheers
                    • KrisidiousK
                      Krisidious
                      Sweeet Plugin.
                      By: Kristoff Rand
                        jgrundman
                        2Tricky,
                        I sent you a private message for additional information, but have since discovered the source of the issue you are having. The problem is not the plug-in, but a limitation within Sketchup. A Sketchup 'curve' is a collection of points and edges, not a true, continuous curve (as a mathematical function). The only way you could get a smoother curve would be to increase the number of segments (edges), but I doubt that would solve the problem you are having.
                        -J-
                        Cheers
                          jgrundman
                          I'll try to fix that. Thanks for the heads-up.
                          @mikaelgu said:
                          Found a small bug:
                          • F
                            fcborik
                            Hello,
                            This plug-in looked very nice, and I downloaded it from the plug-in store. It worked great about 3-4 times, and then I started getting bug-splats. I tried removing and reinstalling the plug-in, with the same results. Fortunately I have the original gear that the plug in made (it really is nice!) and I think I'll be able to take various components from it and make the other gear that I need. However, making brand new gears will be a challenge to me. Any help would be appreciated.
                            Frank
                            • W
                              weldingrod1
                              I'm impressed! Making each tooth a group is an interesting idea!
                              Is there any chance you would be willing to add something to deal with gears where the depth doesn't match the diametral pitch? I would be happy to make a PayPal donation to help this along! My specific application is Hardinge change gears. For some reason, they decided to use 20 degree pressure angle, 22 pitch gears, but with a gear tooth depth corresponding to 29 pitch. The technical description is as follows:
                              Fellows 22/29 Stub Pitch, 20 Deg PA, .003" to .004" Backlash
                              Diameter over wires includes allowance. For backlash and odd number of teeth. Use two .0785" wires for checking over teeth.
                              Face Width - .370" / .375" Bore - .625" / .6265" Keyway - .125" Bore to top of key - .693" No Heat Treating
                              Note: The 22/29 stub pitch has the pitch diameter of a 22 DP gear (N/DP). The tooth depth is that of a 29 DP gear. Whole depth is 2.25/29=.0776". The addendum is the tooth amount above the pitch line (1/29)=.0345". The Std. OD is, PD plus two addendums (n/22) + 2(1/29). Hardinge gears are .005" less than std OD.
                              Here's a description of the Fellows Stub tooth form:
                              http://books.google.com/books?id=x2GThADLN-sC%26amp;pg=PA31%26amp;lpg=PA31%26amp;dq=stub+pitch+gear%26amp;source=bl%26amp;ots=6aF1puqw8N%26amp;sig=QOR5ORl4NdVsN3vc7_6eZ6G-Qwc%26amp;hl=en%26amp;sa=X%26amp;ei=SjinUsSaN8P7kQeI1YGABw%26amp;ved=0CBgQ6AEwAA#v=onepage%26amp;q=stub%20pitch%20gear%26amp;f=false
                              http://books.google.com/books?id=kotyj80OMCoC%26amp;pg=SA2-PA12%26amp;lpg=SA2-PA12%26amp;dq=stub+tooth+gear%26amp;source=bl%26amp;ots=upTfFTO6dI%26amp;sig=p1a0YVGS8o0UPwPBNgGLZeGgoMo%26amp;hl=en%26amp;sa=X%26amp;ei=LjmnUt2DEI-3kAfus4CIBA%26amp;ved=0CEYQ6AEwCg#v=onepage%26amp;q=stub%20tooth%20gear%26amp;f=false
                              • P
                                pastprimitive
                                So this is an absolutely amazing gear plugin! Huge blessing for me and my 3d printer. THANKYOU!
                                Small bug that I fixed. The plugin only except's values in inches for the "pitch radius/rack" user input field.
                                For my 3d printer you pretty much want to work in mm because everything in that world is in mm. Anyhow changes outlined below for making this universally compatible regardless of what unit it designated in the user input fields.
                                Updated plugin for universal unit compatibility in user input fields.
                                Select Code 1:
                                # Generates an Involute Tooth Gear
                                class SPGear
                                	# default values for dialog box
                                	@@teeth = 15
                                	@@ang_pressure = 20.0  # degrees
                                	@@rad_pitch = 10.0.inch
                                	@@face_width = 3.0
                                	@@ang_helix = 0.0
                                	@@ang_bevel = 0.0
                                Change To:
                                class SPGear
                                	@@teeth = 15
                                	@@rad_pitch = 10.0.to_f.to_l
                                	@@face_width = 3.0.to_f.to_l
                                	@@ang_helix = 0.0
                                	@@ang_bevel = 0.0
                                Select Code 2:
                                		@teeth = teeth.abs
                                		@ang_pressure = ang_pressure.degrees
                                		@rad_pitch = rad_pitch.to_f
                                		@face_width = face_width.to_f
                                		@ang_helix = ang_helix
                                		@ang_bevel = ang_bevel.degrees
                                Change To:
                                		@teeth = teeth.abs
                                		@rad_pitch = rad_pitch.to_f.to_l
                                		@face_width = face_width.to_f.to_l
                                • nanolinN
                                  nanolin
                                  As used for a reduction? . as those used in printers Prussian
                                  Thank you
                                    jumpjack
                                    Has this plugin been updated? Does it support worms too now?
                                    It would be also amazing if it supported Sketchy Physics...
                                      Why it does not ?
                                      Just make Components or Groups with your gears and you can use SketchyPhysics for anything! πŸ˜„
                                        jumpjack
                                        It would take years to make each single part of a gear & worm sketchy-compatible.
                                        It would take 2 seconds using a script. πŸ˜„
                                          jgrundman
                                          Jumpjack:
                                          Yes, this will work with Sketchy Physics (SP). That was the primary reason for making this plug-in, hence the "SP" in "SPGears". Specifically, it creates a (mostly) accurate collision mesh, which allows the gears to mesh with each other in SP animations. To make that happen, each tooth had to be a discrete group with its own collision mesh. The downside is that each gear becomes a relatively complex object and can bog down SU and Sketchy Physics.
                                          Everyone:
                                          Thanks for the great feedback and I'm sorry I have not been able to complete any updates. Life keeps getting in the way and I don't know when/if I will get back to it. Until then...
                                          -J-
                                          • C
                                            Chrisu02
                                            Hy guy`s
                                            I like this plugin and using it for 3D printing long time, but now i need to make some hypoid gears but it seems that it won`t work 😞
                                            looking like this:
                                            http://upload.wikimedia.org/wikipedia/commons/thumb/6/61/Gear-kegelzahnrad.svg/220px-Gear-kegelzahnrad.svg.png
                                            I tried out serval value`s
                                            http://imagizer.imageshack.us/v2/800x600q90/537/UaK8Qr.jpg
                                            My problem is that the helix is straight then the bevel value is 0° but i needs to be curved 😐
                                            the next problem is to make them fit together, is it possible to make a differen value (teethsize) as a fixed parameter so the rest of the gear may be calculated to this ?
                                            im no programmer so i dont know if this would even be possible or home much work it would be. ?
                                            Chri
                                            • 2 / 5
