    Any smokers here? Wanna quit?
    822 Posts 42 Posters 331.2k Views 42 Watching
    • iichiversiiI Offline
      iichiversii
      Thanks lads, And I hope ye are all aven success with it as I am, ummm solo that's a great idea, does Mike smoke tho? I know Rich smokes, maybe we could convert him to using a E-Cig and right a review, lol
      Bring on the Rain...
      • soloS Offline
        Mike, Csaba and Rich smoke, hope that next basecamp we are sharing juices πŸ˜• sounds strange.
        • olisheaO Offline
          olishea
          Thanks Stefan. My friends and family are still using EGO tanks so I will get them to try the EVOD instead. EGOs are good beginner vapes, but after a while you need more consistency. I take it you are still using your EGO battery?
          That's the GREAT thing about rebuildables, the wire and wick are very cheap. The tank is expensive to buy initially but you never have to buy an atomizer again. πŸ˜„ The vapour is consistent and very tasty, no dry hits, even when liquid is very low. It really is another level of vape!
          I recommend 0.16mm Nichrome and 2mm Ekowool Silica Wick. At least with a Kayfun anyway. The EVOD works on a similar principle to draw liquid onto the wick.
          Ekowool is non organic and won't burn, it doesn't taint the flavour either....very good stuff.
          Rebuildable atomizers that use a stainless steel wick are notoriously extremely difficult to setup and prime. So best stick to ones that use a silica wick or equivalent IMHO.
          I mixed grape with red bull today for a change, nice combo. The grape has more VG in so I'm getting more vapour production too. πŸ˜„
          I've read a 50/50 VG/PG mix is best. Depends on personal preference too. I can't wait to DIY some juice!
          Yes he does, I believe he was gonna try an alternative vaper that heats natural tobacco. Unfortunate thing with those is they do not create plumes of vapour....and you have to buy tobacco £££. Still healthier than smoking though.
          Good thing about these E-Cigs, you don't need converting. Just have a vape and you won't look back. πŸ˜† Sampling the right flavour is all you need to do.
          oli
            iichiversii
            Ummm, lets convert all 3 of them, 3 reviewers with 3 different products, now that would be very interesting, beta on who will cave first πŸ˜„
            • olisheaO Offline
              olishea
              Yes Pete, cinnamon flavours are VERY popular. I used to buy Big Red chewing gum but they don't sell it in UK anymore. I would also like to try a similar flavour, if it's not too 'hot' πŸ˜„
              Great news Juan! Yes red bull flavour is great, there are many different ones too. It's like choosing between Red Bull/Monster/Relentless energy drinks....slightly different tastes.
              Yes spare batteries are required!
              Pete I am so jealous of your shop. Here is the piece of shit I go to!! They also top up printer cartridges ❓
              http://www.no-match.co.uk/img/st/oldham.jpg
              I am getting somewhere with the Kayfun 3.1. I was coiling my wire too tight which resulted in a disgusting burnt hair taste. 😲
              After 4 re-coils I have almost cracked it. The flavour is OUTSTANDING in a kayfun, I can taste a full palette of flavour. VERY consistent vapour, no deterioration over time. Just smooth, steady vape. Fully adjustable air flow/vapour production. You can fill the atomizer through a special valve in the side too, no messy leaks.
              However, as the Kayfun delivers nicotine so effectively I had to halve the nicotine level in my E-liquid. So now I'm on 10 or 12mg nicotine. The nicotine is waaaaaay too strong at 24mg, I could taste it too. The manufacturer also recommends halving nicotine level when you change to a Kayfun. So I still get the same fix of nicotine, but only use 12mg. πŸ˜„
              I do not recommend the Kayfun to beginners. Get used to vaping first, see what flavours you enjoy and then consider the upgrade when you get sick of buying new atomizers. For most people, I believe an EGO is great and stops you smoking, but for a long-term plan I suggest trying out a rebuildable atomizer.
              It can be very frustrating the first time you coil your own atomizer. How hard can it be to coil a wire round a silica wick? Answer: VERY! You have to coil it just right, not too tight or slack....and with no excess wire. I was almost pulling my hair out with frustration at first, but now I can make the coil almost perfect and the effect is stunning.
              With larger atomizers you need to draw back a bit longer for a huge plume of vapour, but that's OK for me.
              Kayfun 3.1 scores:
              Flavour/Taste: 10/10 (WOW!)
              Vapour Production : 9/10
              Vapour Consistency: 10/10
              Ease of Use: 7/10 (tricky at first, but easy now)
              Ease of Coiling: 8/10 (although much easier than other rebuildable atomizers)
              Ease of Maintenance: 10/10
              Build Quality: 10/10 (unrivalled)
              Feel in the hand: 10/10
              Price: 8/10
              Provario 2.5 Mini scores:
              Flavour/Taste: NA
              Vapour Production : variable voltage, choose your setting.
              Vapour Consistency: voltage stays constant even when battery is low
              Ease of Use: 10/10
              Ease of Coiling: NA
              Feel in the hand 10/10
              Battery Life: 7/10 (get a spare battery)
              Price: 4/10 (expensive for what it is)
              If you are a hardcore vaper and don't mind a larger rig, go for the normal size Provari 2.5 like Pete's. Extension caps are also available for the Provari Mini to use larger batteries but this negates it's small size.
              Photos on the way. πŸ˜„
              oli
                iichiversii
                And saying that iv converted many in my work already, most of the soldiers in my barracks vapour now instead is smoking, I feel like I'm a rep for the the e-cig half the time, lol
                • soloS Offline
                  My wife was just saying that this weekend, when we go out I normally get into some sort of religious discussion with friends and weirdo's, but recently I have been converting smokers instead.
                  • olisheaO Offline
                    olishea
                    Cleric Abu Stoppel!!! πŸ˜†
                    oli
                      iichiversii
                      I found myself in a nite club Saturday wk, and in a packed smoking area I was getting some odd looks, but I was approached on many occasion with queries on the matter, I think I convinced them, I'm wondering now if I go bk to the same club will there be a vapouring area, lol
                      • olisheaO Offline
                        olishea
                        just vape inside! it's legal πŸ‘ I had a vape in tesco today. πŸ˜†
                        oli
                          iichiversii
                          Yeah I did that for a while but I drew the security on myself twice, it was funny at first but the more it happened the more annoying it became, so I just joined the smokers, lol
                          • soloS Offline
                            I tried vaping with the smokers but the smell of tobacco made me sick.
                            • stefanqS Offline
                              stefanq
                              I work in a small shop, only five guys, all smokers. At this moment, only one still light up stickies. At first, they looked strange at me, laughing. Now, we change impressions about liquids and such. One of them tried a fag yesterday (don't understand why) and he told me he was so close to puke .
                              I'm 18 days smoke-free, which is A LOT for an ex-smoker.
                              • olisheaO Offline
                                olishea
                                It was 8 weeks smoke-free for me yesterday. 😍
                                My chest doesn't wheeze or crackle on exhale. I could never completely clear my chest, now my lungs feel clean. I don't cough any more.
                                I feel like my lung capacity has tripled. No dizzy spells, I can blow up balloons without passing out. My VO2 levels must be off the scale now, I can run and train without any noticeable shortness of breath.
                                My blood pressure has reduced. When I coughed from smoking, I could feel intense pressure in my shoulders and hands, like pins and needles pain. I discovered this was a sign of very high blood pressure and it really scared me. I have not experienced any such problems since. My resting heart rate has also decreased πŸ˜„
                                My skin looks better. Less dry, and "grey"....smoking gives a grey transparency to your skin and ages you quicker. I used to have black bags under my eyes constantly, no matter how much I slept. Now they have nearly gone!! I look so much better and feel more confident.
                                WOW. What a difference.
                                oli
                                  mwm5053
                                  I'm like everyone here thought I would never be able to quit 2 weeks for me.
                                  2011 iMac
                                  SU 2015 Pro, 2017 Make
                                  V2 Twilight
                                  macOS Sierra 10.12.5
                                  • olisheaO Offline
                                    olishea
                                    @mwm5053 said:
                                    2 weeks for me.
                                    Excellent!! Good luck and keep vaping. πŸ˜„
                                    oli
                                      mwm5053
                                      From your inspiration Thanks
                                      2011 iMac
                                      V2 Twilight
                                      • stefanqS Offline
                                        stefanq
                                        Just took a picture with my toys Oli, you can tell your friends that EVOD is at least as good as any EGO tanks, if not better. But they look ten times better!
                                        Congrats Walt! πŸ‘
                                        • olisheaO Offline
                                          olishea
                                          Cheers Stefan.
                                          I really want one of these vape stands, the smaller hole is to hold your atomizer at the battery connection while you change the wick and coil. All the other vape stands look like spice racks πŸ˜† They also do a stainless steel version but I can't find a picture, I think they do a range for the EGO too.
                                          http://i654.photobucket.com/albums/uu269/olishea/vape_stand_zpsc028f9dc.jpg
                                          oli
                                          • BoxB Offline
                                            3D printing candidate there Oli.
                                            • 11
                                            • 12
                                            • 13
                                            • 41
                                            • 42
                                            • 11 / 42
