    Action callback - Duh!
    4 Posts 2 Posters 229 Views 2 Watching
      Just occurred to me that I don't need to use java to add callbacks to ruby from webdialogs.
      This works just as well:
      <body>
      <a href="skp;foo@bar">Hello World</a>
      </body>
      • jolranJ Offline
        jolran
        Would you care to further explain, please ?
        This looks intresting BTW, just in time..
        Edit: Ok. gives you "bar" in callback value (key, value).
        So what the difference VS window.location.href = whatever.. ?
        Have you found something to adress the sync issue ???
        Or are you making tabs, heh πŸ˜„ ?
          I've normally attached a JS event which calls: window.location = 'skp:foo@bar'; for all event callbacks from JS to Ruby. Even for links. But it's not needed at all as only activates the custom skp: protocol.
          Still need to use JS for buttons etc - but for <A> elements that triggers callback it can be simplified by adding directly into the HREF attribute.
          • jolranJ Offline
            jolran
            I see.
            Clever solution, anyway. Save's some code.
