    [Plugin] scaleGroupFloat_dj Ver 1.6.5 Feb 15, 2013
    22 Posts 4 Posters 22.7k Views 4 Watching
    • dukejazzD Offline
      dukejazz
      scaleGroupFloat_dj Ver 1.3
      No rendering, everything is done in sketchup.
      Quick work adding color to objects in your model
      nosie, shine, color with transparency = mix block of glowing colors of light.
      Extened options
      Work the color blocks
      save one as target
      then the others use size and move to target.
      💭 each object can have its own light show. wow!
      • pep75P Offline
        pep75
        WOW!
        • dukejazzD Offline
          dukejazz
          This is a importance new release of scaleGroupFloat_dj and its not a beta
          This ver is 1.5,3 Dec 11, 2012
          list=[,"Group scaling tool for objects, scales along XYZ axes.|
          Drop down menu's for quick and easy use of X, Y, Z, XYZ|
          Scale factor for oversize or undersize objects|
          Group move tool for objects|
          Group resize tool for objects|
          Cumulative dolling|
          Local and orgin axes mode|
          Muli inputbox mode for easy to view|
          Converts units|
          2 box readouts and 2 drawing readouts (small and large) |
          show a vector between local and orgin axes|
          shows a center points of sected object|
          extened option|
          2 levels of target saves|
          2 levels of target move to center of object|
          2 levels of target move and size|
          2 levels of target resize to objects|
          2 levels of line up side to axes|
          2 levels to move to corner of a object|
          Lots of readout formats|
          drawBoxPoint_dj to set up target moves inside and outside of objects|
          repeatUndoTool_dj to move through the undo's|
          Two target tool buttons for move and save|
          It's gives high precision float values"]
          • pep75P Offline
            pep75
            Great!
            • dukejazzD Offline
              dukejazz
              Update:
              Feb 15, 2013; scaleGroupFloat_dj v1.6.5 bata
              -add cumulativeScaler_dj rotation around
              Feb 4, 2013; scaleGroupFloat_dj v1.6 bata
              -add cumulativeScaler_dj move around (a step boxpoint)
              -add cumulativeScaler_dj size lenear stepper
              -add cumulativeScaler_dj move lenear stepper
              -fixes
              • dukejazzD Offline
                dukejazz
                cumulativeScaler_dj
                with cumulativeScaler_dj you can step thing to make stairs
                To rotate about a edge step I used a bounding small box boxPoint by rotating upward 15x
                then move a step group into bouning box set
                • dukejazzD Offline
                  dukejazz
                  Fast alinement of any local axes to the orgin axes
                  Here is a fast rotation trick for a rotated component or a group
                  meathod: target save and target move
                  step 1: Make one component unique.( right click context list for making component unique )
                  step 2: Press 1-time left click, the component you want to change. Save target, via scaleGroupFloat_dj (then press ok).
                  step 3: Press 2-times with left button this will set axes to the component and 3-times more will edit the selection of the object. Using the Move to target toolbar, via scaleGroupFloat_dj.(now press ok) This will auto aline component to orgin plain. Now select ouside of component area, now your done.
                  All above steps is shown here
                  Also with the axes tool you can aline any local axes side to the orgin axes
                  • dukejazzD Offline
                    dukejazz
                    Update:
                    Jan 13 2013 scaleGroupFloat_dj v1.5.5
                    • expanded cumulativeScaler_dj (now dose xyz x y z scale,step move, step size and rotation)
                      new
                    ...add thickness to objects
                    ...dolling objects
                    • fix a better error trap
                    -added update a repeat move to target auto mode
                    (frist pass input box then more pressing the button go to auto mode repeat)
                    green target
                    -added update a repeat readout target auto mode
                    white target
                    -added update use save to target to unfreeze the repeat auto modes
                    ( this also will fix scaleGroupFloat_dj and cumulativeScaler_dj lock out by auto mode repeat)
                    red target
                    • added rescale to a very small one demcision (any direction local object) will be flatten to outline wire when you group explode you can then resurface by putting a line accross the retangle.
                    • added the dropping of a boxPoint to a 1d line or a 2d object to make 3d groups for resizing in on the orgin axes
                    5
                    • added the uses of the axes tool (right click move) to rotate objects by steps of orgin
                      (works with scaleGroupFloat_dj and cumulativeScaler_dj
                      maxvector9
                      There is no download link. Where can I download it or is it still in a test fase?
                      • dukejazzD Offline
                        dukejazz
                        by maxvector9 » Yesterday, 1:59 pm
                        There is no download link. Where can I download it or is it still in a test fazes?
                        Re: Ad blocking add ons
                        http://sketchucation.com/forums/viewtopic.php?f=15&t=51766&p=468103&hilit=blocker#p468103
                        may be block cookies
                        by zook247 » April 12th, 2013, 1:29 pm
                        I was unable to download with IE9, I still don't know why it suddenly won't work with IE9 I tried setting my security way down. The pop up blocker was off. But at least Chrome worked.
                        I have been putting in some volunteer work on these plugins for the past year so they are free to down load at this forum.
                        http://sketchucation.com/forums/viewtopic.php?f=323&t=46688
                        http://sketchucation.com/forums/viewtopic.php?f=323&t=45254&p=404860#p404860
                        I have more add on update ideal's to come.
                        1. a new type of paste in place that will work for the Mac
                        2. a web inputBox for scaleGroupFloat_dj
                        I made more memory space available by deleting older ver this may be the problem,
                        also re-link the atachment to this page.
                        If you still have a problem please let me know.
                        • 2 / 2
