    How to place 'Groups' or 'Components' rotated ?
    1 Posts 1 Posters 204 Views 1 Watching
    • renderizaR
      renderiza
      I want to expand my Canvas plugin to add rotation values when inserting groups or Components.
      Problem is that with the code below the object is inserted using Z axis located on (0,0,0) coordinates and I want to rotate the object using cursor z axis coordinates instead.
      I know how to position the position of the vector when I want to raytest but not this...Please Help!
      def activate
        @@sel = Sketchup.active_model.selection[0] ;
        @@ents = Sketchup.active_model.active_entities ;
      end #def
      def onLButtonDown(flags,x,y,view)
       ip1 = view.inputpoint x,y ;
       @point = ip1.position ;
       add_object(@point) ;
      end #def
      def add_object(point)
       vector = Geom;;Vector3d.new 0,0,1  #Want the position to be on cursor
       t = Geom;;Transformation.new @point, vector, 45.degrees
       if @@sel.is_a? Sketchup;;ComponentInstance
         @@ents.add_instance(@@sel.definition,t) ;
       if @@sel.is_a? Sketchup;;Group
         defn = @@sel.entities.parent ;
         @@ents.add_instance(defn, t) ;
      end #def
      [url=https://www.sketchupcode.com/:z3kqsidd]My Extensions ...[/url:z3kqsidd]
