    Copy - a new cloud storage space
    7 Posts 4 Posters 666 Views 4 Watching
    • GaieusG
      It seems things are getting cheaper and cheaper for the users as more and more companies launch their services. This new one is "Copy"
      (Note that I am also selfish and lucrative the same time as if you use my custom link, both you and me will get an extra 5Gb space but I did not only want to "sneak" the info in so you better know)
      • mitcorbM
        mitcorb
        Is this a one time extra 5 for you, or does it happen each new subscriber?
        • daleD
          dale
          Gai
          Check your account to be sure that you got the 5 extra GB.
          I used your link, but it doesn't look like extra on my part.
          Thanks by the way, I'm always full on DropBox
          • davids90gtD
            davids90gt
            I used your link. Thanks for that!
            Does anyone know how to sync a folder thats on my hard drive with the Copy folder? Or should just move the folder(s) into the 'Copy' folder and work on them from there?
            • GaieusG
              It seems an extra 5Gb with each subscriber by my referral (see also attached below - now I have 15Gb already!).
              I don't know, Dale. See the yellow highlighted text in the below attachment - it says you should also get the free 5Gb extra. Maybe you are the one (cleared for privacy reasons) who still has not confirmed the account or has not installed the app yet? (DropBox also requires referred people to install the app in order that the referee gets the extra storage).
              Well, Dave, upon installation of the app, there is a question during the process to select the folders you wish to synch. I opted out of that as I like to only copy stuff to be synched but now I cannot find a setting where I could add folders. Maybe (hopefully?) it exists - it is just too new to me, too.
              • davids90gtD
                davids90gt
                I can choose the file directory or drive that the 'Copy' folder is created. I would like it if I could set it to monitor and sync a specific folder on the same drive. The only option that I know of is to move the 'folder' you want inside the 'Copy' folder.
                • GaieusG
                  Ah, I see. Indeed probably an "add new folder to monitor" function would be nice. I guess they are open to suggestions and improvements...
