    Use of start/commit_operation
    10 Posts 3 Posters 694 Views 3 Watching
      julien.decharentenay
      I am trying to use start_operation/commit_operation to implement undo/redo for a plugin. I am unsure if I am going about it the right way. Attached is a sample of the code that I am trying to write. The purpose is to allow the user to specify coordinates that are used in other parts of the plugin - in this example the coordinates are defined when the left button is released. For visual feedback, the selected coordinates are shown as construction point - which are deleted when the tool is unselected.
      From the redo/undo point of the issue: the tool creates the correct undo/redo statement, but SketchUp also creates "Erase" and "Guide" undo/redo when the tool is deactivated/activated.
      Is there any way to let SketchUp know not to create the "Erase" and "Guide" undo/redo? Or should I use another visual feedback mechanism in place of construction point (such as through the draw function or other)?
      Thanks a lot for your help.
      Julien
      Note: the code also has issues if the undo button is press while the tool is active or the construction point is erased. A test e.deleted? in the deactivate would avoid the error message, but it might be best handled with an entity observer.
      module Hibou
      	class TestingOperationCommitTool
      		def initialize()
      			@cPoints = []
      		end # def initialize
      		def activate()
      			begin
      				dictionary = getDictionary()
      				if ((nCoordinate = dictionary["nCoordinate"]) != nil)
      					for i in 0...nCoordinate
      						x, y, z = dictionary["Coordinate_#{i.to_s}"].split(",")
      						@cPoints.push(Sketchup.active_model.entities.add_cpoint(Geom;;Point3d.new(x.to_f.m, y.to_f.m, z.to_f.m)))
      			rescue Exception => e
      				UI.messagebox("Error; #{e.to_s}.\nBacktrace; #{e.backtrace}")
      		end # def activate
      		def deactivate(view)
      			begin
      				@cPoints.each() { |e|
      					Sketchup.active_model.entities.erase_entities(e)
      		end # def deactivate
      		def onLButtonUp(flags, x, y, view)
      			begin
      				model = Sketchup.active_model
      				inputPoint = Sketchup;;InputPoint.new()
      				inputPoint.pick(view, x, y)
      				if (inputPoint.valid?())
      					model.start_operation("Define coordinate")
      					@cPoints.push(Sketchup;;active_model.entities.add_cpoint(p3d = inputPoint.position))
      					dictionary["nCoordinate"] = @cPoints.length
      					dictionary["Coordinate_#{(@cPoints.length-1).to_s}"] = [p3d.x.to_m, p3d.y.to_m, p3d.z.to_m].join(",")
      					model.commit_operation
      				model.abort_operation
      		end # def onLButtonUp
      		private
      		def getDictionary()
      			return Sketchup.active_model.attribute_dictionary("HibouTestingOperation", true)
      		end # def getDictionary
      	end # class TestingOperationCommitTool
      end # module Hibou
      if (not file_loaded?(__FILE__))
      	UI.menu("Plugins").add_item("Hibou-Testing") { Sketchup.active_model.tools.push_tool(Hibou;;TestingOperationCommitTool.new()) }
      	file_loaded(__FILE__)
        If these guide points are only used for visual illustrations while using the tool then use the View.draw method to draw them to the viewport instead of adding entities. Drawing to the viewport will be faster and cleaner (no extra undo points).
          On a sidenote - you can make operations transparent, using the third and fourth argument of [ruby]start_operation[ruby]. Avoid the third because it's hard to predict what will happen. The second one let you make the operation you commit transparent. However, since it was added in SU7 and until some of the first releases of SU8 the Undo name overwrote the previous one - not something you want, making the "Edit > Undo xxxx" menu item confusing. However, in one of the recent updates of SU8 they fixed this.
          But again,in the scenario you describe you are better off not doing this - just draw directly to the viewport.
            Thanks for the feedback. I think that drawing from the draw method using View.draw is the way forward in my case - and avoid adding entities to the model.
            Beyond the code extract shown, the user is also able to select the input point to change their location (or delete). I used PickHelper.picked_element (or a loop through PickHelper.all_picked) to retrieve the construction point. If I am drawing the point using View.draw, PickHelper.picked_element/all_picked will not pick the point drawn with View.draw and I will have to test using PickHelper.test_point. Is it correct?
            Thanks in advance. Julien
              Correct.
              Btw, I've tried to make an overview over the various methods of the PickHelper: http://www.thomthom.net/thoughts/2013/01/pickhelper-a-visual-guide/
                Thanks a lot for the link and taking the time to writing it. It is very clear and detailed.
                Just a quick question: on the last page (section Segments and Points), the example for testing multiple points faster reads:
                <span class="syntaxdefault">pickhelper</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">init</span><span class="syntaxkeyword">(&nbsp;</span><span class="syntaxdefault">x</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxdefault">y&nbsp;</span><span class="syntaxkeyword">)<br />for&nbsp;</span><span class="syntaxdefault">point&nbsp;in&nbsp;points<br />&nbsp;&nbsp;p&nbsp;pickhelper</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">test_point</span><span class="syntaxkeyword">(&nbsp;</span><span class="syntaxdefault">point</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxdefault">x</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxdefault">y&nbsp;</span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">end</span>
                Shouldn't the second call reads "test_point( point )" or does it not matter?
                  That's true! I've made a typo there. Thanks for catching that. I'll correct it.
                  • Dan RathbunD
                    Dan Rathbun
                    Another thing:
                    DONT:
                    DO:
                    Sketchup.active_model.**active_entities**.erase_entities(e)
                    WHY?
                    If the user changes the editing context, and is within a group or component, the first call will cause SketchUp to BugSplat!
                    I'm not here much anymore.
                    • Dan RathbunD
                      Dan Rathbun
                      FYI: [ Code ] wrapping operations
                        Dan and thomthom, thanks for your time and answer.
