Back edges
Is it possible to find a plugin who is able to show hidden frofiles edges in "back edges" view option (picture 2).
I don't know if there is one but you can unsoft edges you want to be seen, a little tedious.
You will find some hints in this post, but I think there is no final solution for this problem...
You could probably accomplish this with a style, hidden geometry turned on, model transparency turned on a the things you want as hidden lines actually hidden.
this would be good for mechanical draftsman though. maybe someone will have a better solution.
