    ACT- advanced camera techniques - the FOV volume layers
    4 Posts 2 Posters 471 Views 2 Watching
    • cmeedC Offline
      cmeed
      Hello All,
      This plugin is ultimately very frustrating and I'm looking for help. Those of you who have used ACT may have come across the 2 layers that are added called Cameras_FOV_lines and Camera_FOV_volumes when you place a camera.
      After sometime, and with the addition of more cameras, Crazy clipping occurs.
      You can help yourself by deleting these and the clipping stops
      ..... but
      Although I Knew this what i didn't realise is that they reappear. Deleting them dosen't delete them.
      delete the layers - they return
      as you view through each camera each volume / lines return returns too.
      Anyway to stop this behaviour ?
      c
      • mitcorbM Offline
        mitcorb
        Hi:
        numerobis commented on something like this and offered a work around:
        http://sketchucation.com/forums/viewtopic.php?f=15&t=50685#p457428
        • cmeedC Offline
          cmeed
          Thats a very good idea! thank you.
          • cmeedC Offline
            cmeed
            Also my method, to only help ease the problem and retain the ACT scenes (for tweaking), is to use ThomThom selection toys. Use select all on selected layer and you can delete all the frustums in one go.
            C
