    An Auto Unfold Option
    3 Posts 3 Posters 414 Views 3 Watching
    • F Offline
      fuelsguy
      I sent an email to Jim re. his Unfold plugin which I've started using. I'm looking for an auto-unfold option or plugin. Jim wrote one once but it's maybe lost, he's looking, and suggested I post here.
      This is a request for an auto unfold option where there is a continuous unfolding a curved surface with lots of triangles.
      I would like it for RC models where I skin the model with thin foam or flat, bendable sheets of fiberglass. The fuselage is defined as a set of frames, and I can loft between frames as a surface made up from a set of rectangles and triangles. The more triangles, the more accurate the unfold. If there is a large number of segments/triangles doing the unfold manually can be a bit of a pain. An auto-unfold option to start at one edge and unfold the section between two adjacent frames would be great. It doesn't need to unfold in multiple directions, Just one surface and a starting edge. That way I can cut the skins using Phlatprinter and glue them to the fuselage frame quickly.
      Anyone know on such a plugin?
      Thanks in advance,
      Ivor
      • Chris FullmerC Offline
        I'm not sure if you are looking for Jim's or not. But if you are, its here:
        Plugin: Unfold Tool
        This SketchUp script assists the user in flattening, or unfolding, 3d objects onto a 2d plane. Installation Download unfoldtool.zip . M...
        (sketchuptips.blogspot.com)
        • gillesG Offline
          gilles
          Autounfold MattC
          http://sketchucation.com/forums/viewtopic.php?f=323&p=342121#p342110
