    Just idea
    8 Posts 5 Posters 371 Views 5 Watching
    • gillesG Offline
      gilles
      I was thinking of an utility:
      run the tool or plugin,
      draw something and it is selected when you click on another tool.
      does this inspire you?
        eh?
        • gillesG Offline
          gilles
          Let say you have plugin call automatic selection, you active it.
          as far as it is active, when you draw something, like a circle it is automatically selected
          I know there is "Select last entity drawn"http://sketchucation.com/forums/viewtopic.php?t=9892but you must active it after drawing something, and you must active it after each operation.
          By the way it works fine and found it after posting.
          I was rather thinking of a recorder, let say you draw a polyline when you change of tool for example Move, the polyline is automatically selected
          • mitcorbM Offline
            mitcorb
            Is this maybe like a special history stack?
              And when you have drawn an arc, then take the tool rectangle the arc is drawn to the first click of the rectangle ?
              Seems very complex for a curious ergonomy 😄
              Seems my request more urgent for Thomthom 💚
              • gillesG Offline
                gilles
                yes, recording what was made by a tool and what was drawn when leaving the tool.
                This is not a request, just idea.
                • Dan RathbunD Offline
                  Dan Rathbun
                  I do believe there are a few "Selection Memory" plugins
                  I'm not here much anymore.
                  • gillesG Offline
                    gilles
                    the idea was not a selection memory , but to select what is being drawn.
