    (Webdialog) Window match clientsize.
    19 Posts 5 Posters 1.1k Views 5 Watching
    • Dan RathbunD Offline
      Dan Rathbun
      @jolran said:
      I have a callback in Ruby to get in JS "screen.width" and "screen.height", which appears highly supported by all browsers. (it is the Computer screen resolution BTW)
      The screen object is CSSOM View Module, 4.2, which may not be fully supported on older Windows computers, running an older version of the MS WebBrowser control (which SketchUp uses.)
      FULL Testing would be required.
      However there IS a known issue, (on Windows computers,) ie:
      ** object](http://msdn.microsoft.com/en-us/library/ms535868(v) in Community Additions":11opu1oc]Multiple displays
      The screen.width and screen.height properties return the resolution of the primary screen, no matter which screen the browser is in. This is more of an issue, when the two screens have different resolutions. Firefox, Opera, Safari, Chrome all seem to be returning the resolution of the screen that the browser is in.
      ... and ...
      Multiple displays
      The screen object only contains data for the primary system screen. Information for any additional screens to which the desktop is extended is unavailable. For instance, if you have two screens, at 1280x1024 each positioned side-by-side, you might expect screen.availWidth to return 2560. Alas, it will return only 1280, which is the available width of the primary screen.
      This makes positioning popup windows a bit of a pain if the browser isn't on the primary monitor.
      I'm not here much anymore.
      • jolranJ Offline
        jolran
        Lots of good information, thanks Dan.
        I posted this topic more as a question regarding how and why to do callbacks to resize dialogs?
        Since I saw a script doing it, started to think that is something one must do.
        Can't find any documentation about this. Must be some thread burried deep down this forum somewhere...
        On the matter about this method I created. As I suspected you(Dan) found a lot of pitfalls in it. So I put it on the shelf for a while. Might prove to useful later on, one never knows..
          I use callbacks when I want to ensure a given client size. I've not found any other method as the window frame differ from OS to OS - even from window theme to window theme.
            Aerilius
            I'm not exactly sure what you were trying to achieve.
            @jolran said:
            Is that to make the dialog always have the same proportions regardless the user window size?
            It is for the case that you can't predict the size of the content of the webdialog (because you have dynamic content or it depends on browser/font rendering).
            If you just want to set the dialog to a fixed size, you use no more than webdialog.set_size(300, 640).
            ** %(#000000)[doc_width = size[0].to_f w_factor = doc_width/300 # Gives me 5.6 wd_width = doc_width/w_factor]
            This gives for me 300 again. ❓**If we need to adjust the webdialog's size to the size of the html document, we let the html document report its document size (clientWidth not screen.width) back to ruby.
            Unfortunately the SketchUp API sets the window size of the webdialog (including window titlebar and border) and we actually only measure the document size of the webdialog content.
              Aerilius
              If we want to work around this problem we would need a strategy like the following:
              desired window size = document size + window border size
              with
              window border size = original window size - window inner size.
              1. I set the webdialog to a fixed size before showing it, like 380Γ—300.
                dlg.set_size(380, 300)
              2. After showing the dialog, I let JavaScript report the inner size of the window (the visible area where html is rendered, excluding the title bar and window border):
                %(#000080)[window.location.href = 'skp:windowInner@['+(**window.innerWidth**||document.documentElement.clientWidth)+','+(**window.innerHeight**||document.documentElement.clientHeight)+']';]
                (The || operator lets us fall back to an alternative expression for browsers that don't understand the first one.)
              3. The webdialog has a callback that saves the window border size into variables (that where initialized to 0).
                dlg.add_action_callback('windowInner') { |d, params| params = eval(params) **window_border_width** = (380 - params[0].to_i)/2 **window_titlebar_height** = 300 - params[1].to_i d.execute_script('resizeHeight()') }
              4. Then JavaScript reports the size of the html document (the whole document including where it is not visible) and requests to resize the dialog to fit that size:
                %(#000080)[function resizeHeight() { window.location.href = 'skp:resizeHeight@['+(**document.body.clientWidth**||document.body.scrollWidth)+','+(**document.body.clientHeight**||document.body.scrollHeight)+']'; }]
              5. Finally Ruby adds the window border to the document size:
                dlg.add_action_callback('resizeHeight') { |d, params| params = eval(params) width = 2 * window_border_width + params[0].to_i height = window_titlebar_height + params[1].to_i d.**set_size(width, height)** }
              • jolranJ Offline
                jolran
                I see. That make sence.
                As I said, my code snippets was more of a question than a revelation.
                But it should? I hope I havent done any wierd backward-logic again..
                The main Idea was that the dialog should have the same size-proportional regardless of screen resolution.
                Aerilius. I will have a deep look at your code and come back later.
                Have some other boring stuff to take care of first.
                Thank you for your answer and code.
                • jolranJ Offline
                  jolran
                  Finally had the time to go through your explaination, Aerilius.
                  And I now understand what you are doing in your code.
                  That make perfect sence, I got it all backwards.
                  Somehow I got the impression one had to resize dialog window to compensate for different user monitor sizes.
                  Thats why I was fiddeling with screen size. πŸ‘Š
                  And as Dan was pointing out, this can easyly become problematic.
                  I think dlg.set_size will do fine for me. Thanks πŸ‘
                    Dan Rathbun
                    It feels SO good to have an epiphany !
                    πŸ˜„
                    • jolranJ Offline
                      jolran
                      β˜€ Epiphany
                        @jolran said:
                        :enlight: Epiphany
                        Sounds like the name of a girl...
                        • jolranJ Offline
                          jolran
                          Yeah, Tiffany.
                          On the subject about resizing webdialogs. I have been experimenting with dlg.set_size a little today. And it's possible to change layout with the click on a button, for ex. With some callbacks and CSS. Cool! One can therefore have vertical or horisontalmenys as an option.
                          Now since I'm on a roll with strange solutions and odd logic, I gotta ask. Is there any pitfall doing this?
                          I reckon 1 is that the dialog dimensions will only be remembered during sessions(if using @variables), and go back to default setting when restarting Sketchup.
                          I'm just experimenting so it's not sure I would need a function like this, but it would be nice to know if its safe to use.
                            driven
                            don't forget it's not the WWW and a independent browser.
                            SU can collect values and rewrite the html and can use .min_height, .max_height etc. to lock and carry the setting to the next session...
                            overall position is harder to guarantee.
                            • jolranJ Offline
                              jolran
                              Yeah, Trying to get a grasp of that. It's not evident (for me anyway) what one "should do" in ruby and what goes best in html/JS.
                              Storing setting to the next session on the Ruby side, must not attributes be good choice then?
                              You mean :left => 600, :top => 200 ?
                              Why would that be more difficult to store?
                              Thanks.
                                Aerilius
                                Although it is possible we should be careful not to fiddle too much with window management without a good reason. Dialogs in SketchUp store their size and position automatically.
                                If a dialog needs to have a specific size set to work correctly (because of dynamic content etc.) then we can do this. There is even less often a reason to force a specific position on the screen (other than the position from the last session, which the dialog should remember on its own). Window positioning is user land and should be left to be intelligently managed by the window manager (placing windows on free screen area, considering screen size and workspaces etc.).
                                  driven
                                  I think dynamic 'context' is also a good reason.
                                  I have a webdialog that changes it's position, size and content [based on where I moved it to] each open 'model space', SU can't handle that level of user choice.
                                  • jolranJ Offline
                                    jolran
                                    I think I'm going to consider this:
                                    Don't really have a good reason to use it. Just mucking around.
                                    Sounds really advanced. Responsive window.
                                      driven
                                      it's a prototype that seems to work on my mac, might find an excuse to finish it one day.
