    TurboCAD 19 Delux
    9 Posts 5 Posters 644 Views 5 Watching
    • kenK Offline
      ken
      Yes, I know, why don't I go to TurboCAD webs site. I did and I can get more info from my neighbor's dog. One of the most worthless help sites I have ever encountered.
      Lately, TurboCAD 19 has started adding text and dimensions backwards, or upside down and backwards. Been to the help file, nothing, did a Google Search nothing. I was just hoping someone here uses TC 19. Never had this problem with 18, however, once I get the problem, going back to 18 the problem still exist.
      There are a lot of 4 letter words I could use right now, so lets just say, they gotten the last of my money. I am spending to much time trying to get program to function.
      Note, it does't seem to be a driver problem, because I can open a new file and it well add text correctly.
      And to add to the frustration, it will go away for a while then come back. Also, Double CAD has the same problem with the DWG copy of this file.
      Frustrated with a dead line up coming.
      Thanks in advance
      Ken
      • Mike LuceyM Offline
        Mike Lucey
        😆 Good to see you got things sorted out Ken. Is the TurboCad help site that bad? Folks here don't know how lucky they are 😒
        • kenK Offline
          ken
          Well, Mike, I haven't been able to find a web site to help me with TubroCAD. As I upgrade, I don't get an up to date hardback manual. And the old hard back manual I have, has Deluxe and pro information and is not much help.
          Yes, I visit this site each day that I am working. There is a lot of good info and not just on Sketchup.
          Sometimes, I wish to give answer, but the Sketchup genius, are fast. I guess you could call some of the personal residing in this forum as Sketchup First Responders(SFR). You can tell a SFR by his attempts at orbiting every web page.
          I know my problem doesn't have much to do about Sketchup unless you use TubroCAD or Double CAD, but I just thought any info concerning Sketchup could be helpful.
          And to compliment this forum, I now earn my living just using Sketchup. This wouldn't have happen, or I wouldn't be as successful using Sketchup without this forum. And a big kudos to the plugin creators.
          OK, back to work.
          Ken
          • BepB Offline
            Bep
            Hello Ken,
            I am using Double-cad, please send me an example of the problem file per p.m.
            I wil see if i can be of any help.
            Bep
            "History is written by the winners"
            • Jean LemireJ Offline
              Jean Lemire
              Hi Ken, hi folks.
              Turbonot Tubro 😉
              Best regards.
              • kenK Offline
                ken
                Yep, fingers faster than my old eyes.
                @jean lemire said:
                Hi Ken, hi folks.
                Turbonot Tubro 😉
                Best regards.
                • kenK Offline
                  ken
                  Ok, found the problem. It has something to do with DWG's group/blocks coming into TurboCAD. After I exploded all the blocks the problem went away. To explode some of the blocks, I had to import the DWG blocks into Sketchup, than explode, than export as DWG, and then re-insert into TurboCAD DWG file format. A royal pain.
                  I only put this into a Sketchup forum, because I use TurboCAD with Sketchup and I believe there must be others that use TurboCAD to work with DWG drawing.
                  To those who think this is an advertisement for TurboCAD, I won't be buying the updates again. Getting to buggy for me and zero help in their help file or online.
                  This may be closed. Hope it helps someone. Had a long night to finish what should have been a couple of hours work.
                  Ken
                  • mitcorbM Offline
                    mitcorb
                    Interesting that subsequent headings in each reply do not update. Re: Tubro vs Turbo
                    EDIT: That is, until my reply. Now, this really is a curiosity.
                    • kenK Offline
                      ken
                      @bep said:
                      Hello Ken,
                      Bep
                      I have Double-CAD, but rarely use it. Didn't try the file on Double-CAD, just believe that Double-CAD is a subset of TurboCAD and could have the same problem. Didn't mean to imply that Double-CAD did have the problem.
                      Files been corrected.
                      Thanks for the offer.
                      Ken
