    SKP write thumbnail. SIZE?
    7 Posts 3 Posters 749 Views 3 Watching
    • jolranJ
      jolran
      I guess there is no simple way to set the size on Sketchup.save_thumbnail?
      I'm using something similar Dan's snippet.
      http://sketchucation.com/forums/viewtopic.php?t=24876
      It's strange the png's come out 64 X 128 pixels. Most of the times I would rather like to have 64 X 64. I mean Square proportions. Component window has thumbs in thoose proportions for ex..
      • Dan RathbunD
        Dan Rathbun
        No the size is dependent upon the aspect ratio of the viewport, in SketchUp when the file is saved. (Which may be outside the control of your plugin.)
        This is for EXTRACTING whatever pre-made thumbnail is already embedded within the SKP file.
        The SKP file(s) do not need to actually be open within SketchUp.
        If you wish to control the size of a thumbnail, you will have to open the file within SketchUp, and use View.write_image()
        I'm not here much anymore.
        • jolranJ
          jolran
          Ah, I see.
          Im sending thumbs to Webdialog from premade components located in a pluginfolder.
          Quite many of them.
          This seams like to much hassle, I can fix it in the CSS side, no worries..
          Will take a look if I can do something different when saving them though.
          Thanks.
          • jeff hammondJ
            i was farting around with this stuff and needed something similar.. TIG & tt helped me out with this
            model = Sketchup.active_model view = model.active_view keys = { :filename => "/Users/jeff/Desktop/write_image.png", :width => 640, :height => 480, :antialias => false, :compression => 0.9, :transparent => true } view.write_image(keys)
            (obv change the path and others accordingly)
            it's fast though and gives you some decent controls..
            • jolranJ
              jolran
              Nice! Something like this I had in mind.
              Thanks Jeff.
              Let's see if I can make it work with Sketchup.save_thumbnail.
              edit: Hmm, not trivial.
              • jeff hammondJ
                oh.. i was thinking you use this as the thumbnail.. and avoid the save_thumbnail part..
                maybe that's not an option in your situation though?
                • jolranJ
                  jolran
                  Maybe not for this part. I already have a folder with components.
                  But your code might be very useful for a different projekt I have. πŸ˜‰
                  This code would have to run each time to see if the user has added new components, when launching the webdialog. And add thumbs to the list.
                  I already had it working before with 128 px X 64 px, but it would be nice to be able to set the thumbs proportions.
                  As of now I'm clipping the image in CSS with 2 divs. Never mind how I'm doing it BTW.. The main point is that I may not be able to support IE7 with several imagehacks.
                  BTW a side question: Trying to stay "Sketchup like" with the dialog. Could there be any copyright issues, mimicing Sketchup GUI interface?
