    Add items to submenu later on
    11 Posts 3 Posters 1.3k Views 3 Watching
      I can't make it work either.
        Btw, nothing that will affect the result of the menu thing, but your sample code would make more sense as a Module:
        <span class="syntaxdefault"><br />module&nbsp;Test<br /><br />&nbsp;&nbsp;plugins_menu&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">UI</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">menu</span><span class="syntaxkeyword">(</span><span class="syntaxstring">'Plugins'</span><span class="syntaxkeyword">)<br />&nbsp;&nbsp;@@</span><span class="syntaxdefault">my_menu&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">plugins_menu</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">add_submenu</span><span class="syntaxkeyword">(</span><span class="syntaxstring">"mySubmenu"</span><span class="syntaxkeyword">)<br /><br />&nbsp;&nbsp;</span><span class="syntaxdefault">def&nbsp;self</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">my_menu<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxkeyword">@@</span><span class="syntaxdefault">my_menu<br />&nbsp;&nbsp;end</span><span class="syntaxcomment">#def<br /><br /></span><span class="syntaxdefault">end<br /></span>
        When you don't create an instance of a class, use a module.
          SR20VET
          <span class="syntaxdefault"><br />module Test<br /><br />  plugins_menu </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> UI</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">menu</span><span class="syntaxkeyword">(</span><span class="syntaxstring">'Plugins'</span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">  </span><span class="syntaxkeyword">@@</span><span class="syntaxdefault">my_menu </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> plugins_menu</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">add_submenu</span><span class="syntaxkeyword">(</span><span class="syntaxstring">"mySubmenu"</span><span class="syntaxkeyword">)<br /><br /></span><span class="syntaxdefault">  def self</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">my_menu<br />    </span><span class="syntaxkeyword">@@</span><span class="syntaxdefault">my_menu<br />  end</span><span class="syntaxcomment">#def<br /><br /></span><span class="syntaxdefault">end<br /></span>
          Ok. Is there also a reason why I shouldn't use Classes when I don't need instances? I mean does it affect something?
          It also seems that:
          u1 = UI.menu('Plugins'); u2 = UI.menu('Plugins'); u1==u2
          ==> false
            It makes the intent of the code clearer. Classes indicate an object you create instances of. A module is more of a namespace wrapper.
            @sr20vet said:
            It also seems that:
            > ==> false
            Yea, you get a different ruby object each time. And it seem to go out of scope quickly.
              SR20VET
              They still exist in ObjectSpace though:
              #ON STARTUP;
              menus = []; ObjectSpace.each_object Sketchup;;Menu do |obj|; menus << obj; end; menus
              #RESULT;
              [#<Sketchup;;Menu;0x99faea8>, #<Sketchup;;Menu;0xd419134>, #<Sketchup;;Menu;0xd41915c>, #<Sketchup;;Menu;0xd419274>, #<Sketchup;;Menu;0xd57f014>, #<Sketchup;;Menu;0xd57f6cc>, #<Sketchup;;Menu;0xd58219c>, #<Sketchup;;Menu;0xd583e70>, #<Sketchup;;Menu;0xd584474>, #<Sketchup;;Menu;0xd584c6c>, #<Sketchup;;Menu;0xd585a04>, #<Sketchup;;Menu;0xd585d74>, #<Sketchup;;Menu;0xd587494>, #<Sketchup;;Menu;0xd5879a8>, #<Sketchup;;Menu;0xd587a0c>, #<Sketchup;;Menu;0xd5881c8>, #<Sketchup;;Menu;0xd5881f0>, #<Sketchup;;Menu;0xd613da4>, #<Sketchup;;Menu;0xd62fd60>, #<Sketchup;;Menu;0xd62ff54>, #<Sketchup;;Menu;0xd632650>, #<Sketchup;;Menu;0xd6427f8>, #<Sketchup;;Menu;0xd6936bc>, #<Sketchup;;Menu;0xd695728>, #<Sketchup;;Menu;0xd737a3c>, #<Sketchup;;Menu;0xd7380a4>, #<Sketchup;;Menu;0x15ac140c>, #<Sketchup;;Menu;0x15b4de84>, #<Sketchup;;Menu;0x15b4deac>, #<Sketchup;;Menu;0x15b9ef64>, #<Sketchup;;Menu;0x15c87ebc>, #<Sketchup;;Menu;0x15c87f34>, #<Sketchup;;Menu;0x15cb6744>]
              #NAVIGATE TO PLUGINS MENU;
              plugins_menu = UI.menu('plugins')
              #RESULT
              #<Sketchup;;Menu;0x15a3004c>
              #SEARCH OBJECTSPACE AGAIN
              #RESULT
              [#<Sketchup;;Menu;0x99faea8>, #<Sketchup;;Menu;0xd419134>, #<Sketchup;;Menu;0xd41915c>, #<Sketchup;;Menu;0xd419274>, #<Sketchup;;Menu;0xd57f014>, #<Sketchup;;Menu;0xd57f6cc>, #<Sketchup;;Menu;0xd58219c>, #<Sketchup;;Menu;0xd583e70>, #<Sketchup;;Menu;0xd584474>, #<Sketchup;;Menu;0xd584c6c>, #<Sketchup;;Menu;0xd585a04>, #<Sketchup;;Menu;0xd585d74>, #<Sketchup;;Menu;0xd587494>, #<Sketchup;;Menu;0xd5879a8>, #<Sketchup;;Menu;0xd587a0c>, #<Sketchup;;Menu;0xd5881c8>, #<Sketchup;;Menu;0xd5881f0>, #<Sketchup;;Menu;0xd613da4>, #<Sketchup;;Menu;0xd62fd60>, #<Sketchup;;Menu;0xd62ff54>, #<Sketchup;;Menu;0xd632650>, #<Sketchup;;Menu;0xd6427f8>, #<Sketchup;;Menu;0xd6936bc>, #<Sketchup;;Menu;0xd695728>, #<Sketchup;;Menu;0xd737a3c>, #<Sketchup;;Menu;0xd7380a4>, [b]#<Sketchup;;Menu;0x15a3004c>[/b], #<Sketchup;;Menu;0x15ac140c>, #<Sketchup;;Menu;0x15b4de84>, #<Sketchup;;Menu;0x15b4deac>, #<Sketchup;;Menu;0x15b9ef64>, #<Sketchup;;Menu;0x15c87ebc>, #<Sketchup;;Menu;0x15c87f34>, #<Sketchup;;Menu;0x15cb6744>]
              • Dan RathbunD Offline
                Dan Rathbun
                Please (and I know I have keep scolded on this subject ...,) do not change Ruby Core classes and modules.
                Test IS a Ruby Core module (that ALSO has SketchUp API extensions added into it.)
                The general rule is, that there is NEVER any good reason for YOU to write code FOR YOUR OWN USE, that is not wrapped within YOUR OWN UNIQUE MODULE NAMESPACE.
                So following that rule ... use VET::Test as your OWN custom test module.
                ALSO.. do not override the global method test() within the TOPLEVEL_BINDING as it will override it for EVERYONE else's modules and classes.
                Instead, if you wish to override the test() method, do it locally within one of YOUR OWN module or class namespaces.
                I'm not here much anymore.
                  SR20VET
                  Don't worry. I use my own namespaces 😄
                  Was for illustrating purposes.
                    Dan Rathbun
                    @sr20vet said:
                    Don't worry. I use my own namespaces. Was for illustrating purposes.
                    Yes it appears that the C++ side garbage collection is cleaning up the references on it's side, leaving our Ruby references orphaned.
                    At one time I thought I had this working but now I cannot get it to work.
                    Is this a PC bug or is it also bugged on the Mac ?
                      Dan Rathbun
                      It seems that the references to submenu objects last a bit longer than references to "topmenu" objects.
                      Re: [API] Menu.add_item( caption, index )
                      BUT.. how much longer ? ... and why ?
                      Is it a block scope issue ?
                        Dan Rathbun
                        The two main problems we have:
                        (1) Menu object references on the C++ side are garbage collected quite quickly, and the references on the Ruby-side become invalid.
                        We can live with having to recall UI.menu() to get new valid references to the 9 top level menus, but ...
                        (2) the menu#add_submenu method should return a new valid reference to the submenu IF IT ALREADY EXISTS, or create the submenu if it does not.
                        Currently it just creates a duplicate submenu.
                        I am sure that this issue has already been logged.
                        I so much hope that SketchUp v2013 will fix this (if no more updates to v8 will be released.)
                        So.. for now... once the startup cycle is complete, we cannot add items to ANY of the previously created submenus.
