    Rounding numbers
    7 Posts 4 Posters 487 Views 4 Watching
    • genma saotomeG Offline
      genma saotome
      I have a number I want to round to 6 decimal places before changing it to a string for output. The code I have in hand is (self*1000000.0).to_i.to_f/1000000.0 which appears to simply truncate instead of doing a true rounding.
      As part of the float class, round(n) is a method in the Ruby language but I see no reference to it the Sketchup API. Is there a way to get around the SU API to get to the language methods?
      Suggestions?
      • Chris FullmerC Offline
        You can use round(n) or whatever the syntax is. It comes as part of the standard ruby 1.8.6 that comes with SU. The SketchUp API only documents methods and classes and modules that SU adds to the standard ruby. I'm sure I got some of the fine details of that wrong, but that is the general idea (awaiting a more complete answer from a more knowledgeable source). 😄
          Jim
          Nope. Float#round(n) didn't show up until sometime after 1.8.6.
          If you are using "self", then you are doing it wrong. It's bad style to add or modify built-in methods in SketchUp's shared Ruby environment.
          For the rounding, you never actually round - the docs say to_i truncates to an Integer.
          (self*1000000.0).round().to_f/1000000.0
            Wow seriously? I was convinced I use a rounding method...I'm clearly losing it!
              Class: Numeric (Ruby 1.8.6)
              Class : Numeric - Ruby 1.8.6
              (ruby-doc.org)
              It´s one of them methods tha´ts commonly modified. 😞
                genma saotome
                Seems like updating the version of ruby used for Sketchup would he most helpful. Any reason for Trimble to do that as a routine step or is this one of those don't fix it if it ain't broke situations?
                  They've tried earlier, but it was troublesome. However, from the talks at Basecamp it did appear they are again looking to update the Ruby core.
