    [REQ]JointMove like JointPushPull
    9 Posts 4 Posters 593 Views 4 Watching
      MartinK
      Hello,
      I was wondering if there is a plugin that will perform similar to Joint Push Pull but Move instead. I've attached a simple SU model to show what I mean.
      Thanks.
      JointMoveTest.skp
      JointMoveTestV6.skp
        Post in V6 or a little image?
          MartinK
          Version 6 file added to OP
            Thx πŸ˜„
            Maybe with Vertex tools by ThomThom(no time to try 😞
            or maybe just the move tool + scale tool πŸ˜„
            • gillesG
              gilles
              ctrl+moveTool. A guide line can help.
              • pbacotP
                In this example both scaling and move are required. To do this getting the face into the same position as JJP with some degree of accuracy would would be difficult with native tools
                • gillesG
                  gilles
                  you are right, it was a too quick reply. Shame on me.
                  • pbacotP
                    Here's one with a few steps and plugins, but I wonder if someone has a new plugin up their sleeve?
                    You have to draw in some edges, in this case the four miter lines to help Curviloft
                      MartinK
                      Thanks for the suggestions so far.
                      pbacot: I have used that method before. It's fine for simple objects, but gets more difficult for geometry that is more complex or curved in 2 directions. I'm just hoping to find a way that doesn't require as many steps. Just getting lazy in my old age.
                      Thanks again.
