    [Utility] make-rbz
    2 Posts 2 Posters 230 Views 2 Watching
    • danielbowringD Offline
      danielbowring
      Ruby-based tool to make RBZ files.
      Source and docs available at https://github.com/dbowring/make-rbz
      here's the contents of the README (converted to BBCode)
      make-rbz utility
      Make RBZ files for Sketchup
      (c) 2012 Daniel Bowring, released under GPL.
      Requirements
      • Ruby 1.8 (with rubyzip2) or Ruby 1.9 (with rubyzip)
      • Ruby gems
      Usage
      > $ make-rbz.rb -h
      > Usage ; ruby make-rbz.rb [OPTIONS]
      >     -v, --[no-]verbose               Run Verbosely
      >     -t, --[no-]strict                Run in strict mode
      >     -f, --[no-]force                 Force file overwrites
      >     -o, --outname=NAME               Set Output File Name
      >     -p, --outpath=PATH               Set Output File Path
      >     -s, --source=PATH                Set Source Directory Path
      >     -r, --read-stdin                 Set File name from STDIN
      >     -i, --ignore=PATTERNS            Ignore files matching glob pattern
      • -v, --[no]-verbose
        • Run in verbose mode
        • default OFF
        • This will print the name of every file added to the RBZ to STDOUT
      • -t, --[no-]strict
        • Run in strict mode
        • default ON
        • Catches common errors
          • Setting filename multiple times
          • Having a directory in the filename
      • -f, --[no-]force
        • Force overwriting the RBZ file if it already exists
        • default OFF
      • -o, --outname
        • Set the filename of the RBZ file
        • .rbz will be automatically added if excluded
        • defaults to the name of the active directory
      • -p, --outpath
        • Set the output directory for the RBZ file
        • Defaults to current directory, .
      • -s, --source
        • Set the source directory
        • defaults to src
        • Contents of this directory will be added to the RBZ file
        • Acts as the root of the RBZ file
          • that is, the directory itself will not be added to the RBZ file, but all of its contents will
      • -r, --read-stdin
        • Read the RBZ filename from STDIN
        • Example
          • git describe | ruby make-rbz.rb -r may produce v1.0.0.rbz
      • -i, --ignore
        • Add given glob patterns (separated with a ,) to the ignore list
        • Files matching this pattern will not be added to the RBZ file
        • Example
          • ruby make-rbz.rb -i '.exe'* to exclude Windows executables
        πŸ‘ πŸ‘
