    Is mac set_html working, again?
    16 Posts 2 Posters 2.8k Views 2 Watching
      Yea, I replaced the path to a file on my desktop. I checked it was found by Ruby by File.exist?
      What Safari version do you have?
      Mine is Versjon 5.0.6 (5533.22.3)
        driven
        actually, I added file:/// and they still all work, do these or the others run on a pc?
        html=<<SETHTML
        <img src="file;////Users/johns_iMac/Desktop/400px-Lion_Rampant.png" alt="test image" title="my test1" >
        SETHTML
        dlg1 = UI;;WebDialog.new("it works again1", true,"img", 250, 250, 150, 150, true);
        dlg1.set_html(html)
        dlg1.show_modal
        dlg2 = UI;;WebDialog.new("it works again2", true,"img", 250, 250, 400, 150, true);
        dlg2.set_html(%q(<img src="file;////Users/johns_iMac/Desktop/400px-Lion_Rampant.png" alt="test image" title="my test2" >))
        dlg2.show_modal
        dlg3 = UI;;WebDialog.new("it works again3", true,"img", 250, 250, 650, 150, true);
        dlg3.set_html(%Q(<img src="file;////Users/johns_iMac/Desktop/400px-Lion_Rampant.png" alt="test image" title="my test2" >))
        dlg3.show_modal
        imgPath="/Users/johns_iMac/Desktop/400px-Lion_Rampant.png"
        html1=<<SETHTML
        <img src="file;///
        SETHTML
        html2=<<SETHTML2
        SETHTML2
        html=(html1 + imgPath + html2)
        dlg4 = UI;;WebDialog.new("it works again4", true,"img", 250, 250, 900, 150, true);
        dlg4.set_html(html)
        dlg4.show_modal
        imgPath=(File.expand_path("~/Desktop/400px-Lion_Rampant.png"))
        html1=<<SETHTML
        <img src="file;///
        SETHTML
        html2=<<SETHTML2
        SETHTML2
        dlg5 = UI;;WebDialog.new("it works again5", true,"img", 250, 250, 1150, 150, true);
        dlg5.set_html(html)
        dlg5.show_modal
        incase you need a rampant lion for your desktop
          Yes. With and without file:///
            driven
            WebDialog is using
            %(#004080)[Browser
            Unknown Mozilla
            Browser Version 5.0
            Operating System
            Apple OS X
            User Agent String Mozilla/5.0 (Macintosh; Intel Mac OS X 10_8_2) AppleWebKit/536.26.14 (KHTML, like Gecko)]Safari is using
            %(#008000)[Browser
            Apple Safari
            Browser Version 6.0
            Operating System
            Apple OS X
            User Agent String Mozilla/5.0 (Macintosh; Intel Mac OS X 10_8_2) AppleWebKit/536.26.17 (KHTML, like Gecko) Version/6.0.2 Safari/536.26.17]
            they are quite different things, as I keep telling people...
            easiest way to confirm...
             wwhdlg = UI;;WebDialog.new("wot_works_here", true, "wwh", 739, 641, 50, 50, true);
             wwhdlg.set_url "http://www.findmebyip.com"
             wwhdlg.show_modal
             wwhdlg.navigation_buttons_enabled=true
              driven
              /AppleWebKit\/([\d.]+)/.exec(navigator.userAgent)
              or you can paste this in Web Inspector
                Browser
                Unknown Mozilla
                Browser Version 5.0
                Operating System
                Apple OS X
                User Agent String Mozilla/5.0 (Macintosh; Intel Mac OS X 10_5_8) AppleWebKit/534.50.2 (KHTML, like Gecko)
                /AppleWebKit/([\d.]+)/.exec(navigator.userAgent)
                ["AppleWebKit/534.50.2", "534.50.2"]
                Is it a different version in WebDialogs due to compatibility reasons?
                  driven
                  Safari is an Application and Apple keeps it ahead by keeping WebCore and WebKit at least one step behind, I test SU things in Safari for 'future proofing' rather then current state, I have a simple browser I built to the Webdialog spec for 'current state' external testing, but it's easiest inside SU with Web Inspector.
                  I 'think' that if you can update WebKit manually, but I'd need to look it up...
                    Well, I was about to just update my OSX - seeing how it's obsolete...
                      I split off the conversation about upgrading OSX to a separate topic: http://sketchucation.com/forums/viewtopic.php?f=180&t=49371&p=443690#p443690
                        driven
                        the other part of set_html that was broken, was XMLHttpRequest
                        here an almost functioning test... at the moment you need to use a link with a full href to get the css etc...
                        or adding the links to your header might work. Bit odd but works
                        html1=<<SETHTML
                        <html>
                        <head>
                        <script>
                        function requestIt() {
                            var req = new XMLHttpRequest();
                            req.open('GET', 'http://www.sketchup.com/index.html');
                            req.onreadystatechange = function (evt) {
                                  /* readyState 4 indicates the transaction is complete; status 200 indicates "OK" */
                                  if (req.readyState == 4 && req.status == 200) {
                                      var log = document.getElementById('log');
                                      log.innerHTML = req.responseText;
                            req.send(null);
                        </script>
                        <style> body {background; url("file;///#{imgPath}") no-repeat center center fixed;
                        	-webkit-background-size; cover;}</style>
                        </head>
                        <body>
                            <button onclick="requestIt();">Click to Request</button>
                            <div id="log"></div>
                        </body>
                        </html>
                        SETHTML
                        html=(html1)
                        dlg6 = UI;;WebDialog.new("it works again6", true,"img", 850, 850, 150, 450, true);
                        dlg6.set_html(html)
                        dlg6.allow_actions_from_host("")
                        dlg6.navigation_buttons_enabled = true
                        dlg6.show_modal
                          driven
                          I nicked this from the other thread, because thought it was appropiate to something I wanted to say...
                          @thomthom said:
                          @jolran said:
                          So doing like that and putting in an image for button like below would work on Mac?
                          It used to work, then it didn't. Then it might be working for some. But not me.
                          I wouldn't rely on it.
                          I agree, for now, for general release plugins, but I like using set_html with Heredoc for simple short scripts, like toolbar buttons.
                          If your on the 'evil' WebKit version you could use the same basics but write to file the use set_file
                          I'll dig up the unix call to check webkit version, then a conditional could do either/or
                          thoughts...
