    Toolbars
    18 Posts 5 Posters 1.7k Views 5 Watching
    • Dan RathbunD
      Dan Rathbun
      @jim said:
      What's the differece between an @variable and a @@variable in the previous post's scope?
      I've always just used class variables ( @variable) since they are "global" in a module's scope.
      AN @@variable is a class (or module) variable.
      AN @variable is an instance variable. Yes it has global scope within the module, because there is (and can only be,) only one instance of the module.
      I use both. @@ var for things you might otherwise use a global var for. (Settings and the like.)
      And then I use @ vars for values that change a lot, but need to be available to all methods.
      The big difference comes when it's a Mixin module. @ vars can be mixed into the target class or module. Not sure about the class vars.
      I'm not here much anymore.
      • Dan RathbunD
        Dan Rathbun
        And since a toolbar reference is not going to change during the session, I prefer to use an @@var.
          driven
          hi
          I'm re-jigging my plugins on_off ruby that's part of a larger toolset and I split of the SU auto-reload as a separate button.
          This lets me make a few choices, then reload SU.
          On using I thought, 'what if I change my mind', so I only show the current state button to start then turn on it's counterpart when it runs.
          because I can't remove the first button, I turn it's command to nil, and have a rescue smart alex puts.
          so you only ever get two buttons and they only switch on first click.
          is there a better way?
          @rtb = UI;;Toolbar.new("mac Dev Tools")
          @path = Sketchup.find_support_file("Tools/on_off") #if your ruby's are OFF this still shows up
          roncmd = nil
          roffcmd = nil
          roncmd = UI;;Command.new("rbON") {Sketchup.plugins_disabled = false;
          roncmd = nil
          begin
          @rtb.add_item(roffcmd)
          rescue
          puts "I'm one shot per session"
          roffcmd = UI;;Command.new("rbOFF") {Sketchup.plugins_disabled = true;
          roffcmd = nil
          begin
          @rtb.add_item(roncmd)
          rescue
          # button image paths
          onicon=(@path + "/images/on.png")
          officon=(@path + "/images/off.png")
          roncmd.large_icon = roncmd.small_icon = onicon
          roffcmd.large_icon = roffcmd.small_icon = officon
          roncmd.tooltip  = %q(Plugins will be "ON" at next StartUp)
          roffcmd.tooltip = %q(Plugins will be "OFF" at next StartUp)
          if !Sketchup.plugins_disabled? === true
          @rtb.add_item(roffcmd);
          else
          @rtb.add_item(roncmd);
          end #if
          can toolbars buttons be disabled?
          you need an image folderif you want to test
            http://www.sketchup.com/intl/en/developer/docs/ourdoc/menu#set_validation_proc
            • Dan RathbunD
              Dan Rathbun
              And unfortunately .. currently we cannot change via the API, the button image that a UI::Command instance is associated with, although doing so is and has long been, a basic feature of Windows Microsoft Foundation Classes (MFC) UI programming. (So we could do it with system calls, using Win32API, etc.)
              I do believe this is or has been logged as an API feature request.
              So for now, you are limited to graying them out.
                driven
                TT + Dan,
                I can't seem to get that to work on a mac.
                do I need to create a menu item as well, grey it out, and the button follows?
                Error: #<NoMethodError: undefined methodset_validation_proc' for #UI::Toolbar:0x113cb6ec>`
                I have a menu entry for the 'master' toolbar, but don't really want/need lots of submenu items.
                  driven
                  I have an applescript 'somewhere' that tracks the toolbar's window position then positions a replacement window in the exact spot, can't remember why I stopped pursuing that approach, Maybe I switched to a webDialog for that one... I'll dig it up
                  • Dan RathbunD
                    Dan Rathbun
                    @John: set_validation_proc is an instance method of your UI::Command class object (which can be assigned to BOTH a menu item, AND a toolbar button, at the same time, or only one or the other, as you desire.)
                    If you are not using UI::Command objects for menus (some don't,) then set_validation_proc is an instance method of the submenu object ( Sketchup::Menu class,) that is the parent of the menu item.
                    For a menu NOT using a UI::Command:
                    @item = @submenu.add_item("My Task") { do_my_task() }
                    @submenu.set_validation_proc(@item) {
                      @task_allowed ? MF_ENABLED ; MF_GRAYED
                    For a UI::Command, that can be used for menu item AND/OR toolbar button:
                    @my_task_cmd = UI;;Command("My Task") { do_my_task() }
                    @my_task_cmd.set_validation_proc {
                    @submenu.add_item @my_task_cmd
                    @toolbar.add_item @my_task_cmd
                    Notice how one of the calls to set_validation_proc has an argument (a menu item,) and the other (when used with a UI::Command,) does not.
                    πŸ’­
                    • Dan RathbunD
                      Dan Rathbun
                      Because it's an ugly Hack? πŸ˜›
                      Because it creates too many entries in the View > Toolbar menu ?
                      Because it clutters the plist with too many toolbar entries ? (This current is a big issue on Windows as toolbar entries go into the Registry.. and slows SU loading way down the more there are!)
                        @driven said:
                        TT + Dan,
                        Sorry, wrong link.
                        http://www.sketchup.com/intl/en/developer/docs/ourdoc/command#set_validation_proc
                        Use it on the Command object.
