    Centrifugal shifting
    7 Posts 2 Posters 1.3k Views 2 Watching
      gepponline77
      Hi!
      I'm trying to realize a centrifugal launcher.
      It is just a cilinder with a threaded ring that rotat and i want the ring to be launched or unthreaded from the cylinder.
      I can't understand which joint to use with the ring w how.
      Can anyone help me?
      I attach my project.
      centrifugal.skp
      • chriC Offline
        chri
        hi GEP
        The probleme is not with the joint.
        In first time , you need to make a pipe .
        Please take a look on the next picture .
        In a second time , you need to create a cylinder
        Please , look at my file , centrifugal 2
        if you'd like more explanations , take a look on these 2 topics :
        http://sketchucation.com/forums/viewtopic.php?f=61&t=48430
        http://sketchucation.com/forums/viewtopic.php?f=61&t=46796
        Have fun
        chri
        centrifugal 2.skp
          gepponline77
          So let me clear concept in my mind.
          I have to create a cylinder not from a circle but with multiple segments?
          Is this the only way?
          No settings for the ring group to make it work as a real ring?
          I noticed that if i don't group the ring with the cylinder, i can use a normal pipe, but the ring shift on the wrong direction, how to change it?
          • chriC Offline
            chri
            PLEASE TAKE A LOOK ON MY TUTORIAL --
            YOU WILL SEE THE AVAILABLE OBJECTS --
            UNNECESSARY
            I DON'T THINK SO
            PLEASE TAKE A LOOK ON THE TOPIC ABOUT READBACK COLLISION
            PERHAPS IT WILL HELP YOU TO HAVE A BETTER UNDERSTANDING ABOUT COLLISION
            http://sketchucation.com/forums/viewtopic.php?f=61&t=48693
            sorry for my english
            christian from France
              gepponline77
              As I told you, If I don't group the object, it work.
              I attach an example....
              Inthis example the problem is that i can't stop the centrifugal excursion at the collision with the main block.
              Pitch.skp
              • chriC Offline
                chri
                Hi GEP
                Please , try this
                bye
                chri
                Pitch 2.skp
                  gepponline77
                  Perfect! It seems to work now (and without creating a multiple coyies ring) πŸ˜‰
