    UI::WebDialog => set_html => large HTML pages
    12 Posts 3 Posters 2.2k Views 3 Watching
    • N
      niccah
      @thomthom said:
      It's not really clear to me what the "problem" is. Can you specify?
      Oh sorry... okay, let me explain the "problem" a little bit more in detail...
      I have a plugin for Sketchup and I need a formular, where I can set a lot of options. So, I'm using a WebDialog and the content is written in a string.
      • advantage: I can insert some ruby variables (for example: "<input type="text" value="" + rubyVariable + """
      • disadvantage: The Webdialog gets larger and larger, so the string gets larger and larger => the code gets unclear.
      Now, my question is: can I write all the html code in an external file? So, normal text file, I can import with "File.open...". But then, I can't use some ruby variables in the html code.
      So, for me (a more or less Ruby newby), it is not clear what's the best way to handle large WebDialogs.
      @thomthom said:
      By the way: set_html doesn't work under OSX after an Safari update.
      Oh, that's an important hint... how I can handle this problem? Thanks a lot, ThomThom for your help!
        Don't understand what you mean by not being able to use ruby variables...
        If you compile a string with HTML and injected ruby variables, and use #set_html it's the same as if you wrote the same HTML to a file and used #set_file. I'm still not quite "getting it". πŸ˜•
        Write out a temp file with the compiled HTML, then use #set_file.
          If you're new to WebDialogs in SketchUp you want to have a look at this thread: http://sketchucation.com/forums/viewtopic.php?f=180&t=23445#p198883
          • N
            niccah
            Oh, that was the perfect hint. You are right, I'm realy new to WebDialogs. So I read a lot the last few days and now, I know, my question was stupid πŸ˜„
            However, thanks for your endurance!
              No worries. Just keep asking.
              Btw, what are you creating?
              • N
                niccah
                Oh, I started a big big project...
                On the one hand I love to play with my milling machine, on the other hand, I'm very interested to learn to write some Sketchup plugins.
                So my project:
                You can select some faces of your model, enter some dimensions of your milling tool and you get the right GCode. Now, I'm coding the userinterface of this plugin.
                I hope, I can publish first beta versions in the next fex month...
                  hm... I wonder is there was someone else also working on generating GCodes....
                  • Chris FullmerC
                    gcode site:sketchucation.com/forums/
                    There have been people talking about it in the past. I did not read any of those threads to see if anyone has some good code or a plugin for it. But there might be something there.
                      I think Noel was doing something. I've given him a nudge.
                      • N
                        niccah
                        Thanks guys for the hints! I got a message from Noel!
