    Craftsman Tool Chest
    39 Posts 5 Posters 3.8k Views 5 Watching
      mwm5053
      This is a scan of the article so I was just following as close as I could and see if I could do it in SU probably won't build it that way however. But after all it is a Craftsman Tool Chest.
      2011 iMac
      SU 2015 Pro, 2017 Make
      V2 Twilight
      macOS Sierra 10.12.5
        Ah. I see. That seems like a lot of work to me. Good SU practice, though.
        • boofredlayB
          boofredlay
          Aw man, I saw the title and thought you were making one of these. 😄
            mwm5053
            Check it out, it was a lot trouble but it was good practice I used your method in the stopped chamfers tut cut and paste in place and used the solid tools for the first time since I bought SU
            chisel rack_1.skp
            2011 iMac
            V2 Twilight
              mwm5053
              @ Eric maybe someday. Here's peek I got so far
              2011 iMac
              V2 Twilight
              • boofredlayB
                boofredlay
                That looks great. I long to make one of those myself someday. My tools are just laying around inside the cart I posted above, not very organized.
                If I may, a visual tip with SU. If you turn your back face color to a black or near black you wont' get the white jaggies showing up in your image export.
                  mwm5053
                  Thanks Eric great suggestion 👍
                  2011 iMac
                  V2 Twilight
                    Yes, that's a good suggestion. I do that before I make image exports although I use my default green back face color while drawing.
                    Walt, it looks like a good model. Keep up the good work.
                      davidheim1
                      Am I missing something? Seems to me that modeling a tapered hole and slot for the chisels is infinitely easier in SketchUp than in real life. In real life, I'd probably use a reamer, like the one Dave R. mentioned that Windsor chair makers use. In SU, I'd make a hole for the smallest diameter, then use the Offset Tool to set the largest diameter on the top face of the board. With the Move/Copy Tool, I'd pull the smaller diameter over to the larger one, tapering the hole. Then, for the slot, I'd turn on X-Ray view and hidden geometry. Trace over hidden geometry lines to mark where the tapered slot falls on the hole, then carry those lines through the board and across the faces. A little erasing, and I'm done. Took longer to type these abbreviated instructions than it did to do the modeling.
                      dh
                        David, I agree with you. Modeling it would be easier than making the real thing. I'd still just use the counterbored holes in real wood.
                        I can think of several ways to create the tapered hole in SketchUp. Using Cardinal Points is one, Autofold, another.
                          mwm5053
                          As I agree with Dave I wouldn't go to the trouble to do the tapered holes in the shop a simple hole and dado as he said earlier but he sorta challenged to see if I could do it in SU so this is how I went about it. Circle tool, made cylinder to 1/16 more than top af taper with PP, scaled bottom of cylinder to ah better to just show you
                          Sorry about video quality need to improve on that.
                          2011 iMac
                          V2 Twilight
                            Good work, Walt.
                              mwm5053
                              Thanks, that's an extreme compliment coming from my mentor. 😄
                              2011 iMac
                              V2 Twilight
                                mwm5053
                                Well moving forward, sometimes 1 step forward 2 steps back. the chisels were somewhat tedious but it's all about experimenting and trial and error. I hid the middle drawers so the inside was visible.
                                Thanks for looking
                                2011 iMac
                                V2 Twilight
                                  Nice work. I think your drawers should have green felt in them So should those in the tool chest. 😄
                                  • boofredlayB
                                    boofredlay
                                    That is looking great Walt. I am impressed.
                                      mwm5053
                                      Thanks guy's I think I'm going to model some more tools to put in to it. What's a tool chest without tools right. I'm thinking of a tri square and mallet off the bat. But at a loss for further options. Maybe a few suggestions .
                                      2011 iMac
                                      V2 Twilight
                                        How about a marking gauge, a striking knife, a little block plane like the LN bronze plane? A dovetail gauge, a sliding bevel gauge, dividers (inside, outside and straight), caliper a couple of pencils and a piece of chalk.
                                          mwm5053
                                          Ya why didn't I think of that. Will keep me busy for a while 👍
                                          2011 iMac
                                          V2 Twilight
                                            And out of the bars. 😄
