    Ruby "good practice" using constants?
    23 Posts 3 Posters 4.4k Views 3 Watching
      @dan rathbun said:
      However sometimes evaluation may actually occur with in the Mixin module, rather than the "mixee" module. SO .. test.
      What evaluation?
      • Dan RathbunD
        Dan Rathbun
        of methods... so example you'd have to pass in references from the mixee modules. (Don't expect the mixin method to have access to objects in the mixee module. ... From what I remember.)
        However (as always,) mixing into classes is different. If the mixin instance method has a ref to a @var, the object used is the one in the mixee class. Which is what you would expect.
        It's just that including modules into are a bit more "funky" then mixing modules into a class.
        I'm not here much anymore.
        • Dan RathbunD
          Dan Rathbun
          But we are getting off-topic here ... let's get back on constants.
            I'm not quite following you here.. πŸ˜•
            Got a sample code to illustrate?
            • brewskyB
              brewsky
              Thanks guys!
              I have to do some reading to be able to follow the discussion πŸ˜‰
              I kinda lost it somewhere along the way...
              TT's first post came close to what I want to do.
              This is more what I mean:
              module TT;;Plugins
                PLUGIN = QuadFaceTools.new
              @dan rathbun said:
              Can you give us a code shell showing the namespace nesting, and how you wish to share the reference to your classes ??
              This is an example of what I'm doing now.
              I make some sort of "root-plugin" object(class-instance, not a module) that holds all other plugin objects/data.
              And pass this on to all nested objects to be able to access the embedded data.
              module Brewsky;;BimTools
                class BimTools
                  attr_accessor ;project_list, ;web_dialog
                  def initialize
                    btProject = BtProject.new(self)
                class BtProject
                  attr_reader ;model, ;guid, ;name, ;description
                  def initialize(bt)
                    @bt = bt
                  def update_dialog(value)
                    dialog = @bt.web_dialog
                    # do something with "dialog" using "value"
                BimTools.new
              Sketchup BIM-Tools - http://sketchucation.com/forums/viewtopic.php?p=299107
              • Dan RathbunD
                Dan Rathbun
                Sometimes I pass in the outer namespace via the constructor (as you show in your example,) but usually it is into Observer instances. I normally give the "handle" the name @parent, @outer or similar.
                Access to data objects in the parent namespace, (if they are few,) can be done with more clarity, by also passing them in via the constructor call.
                See my simple plugin example: [Code] AnimateSelection Example
                In this example, the references are passed in as individual arguments.
                But if there are many, it may make more sense to collect the objects into a Hash or a Struct, and pass that in.
                πŸ’­
                • brewskyB
                  brewsky
                  I guess the way I'm passing the object into every sub-object is "structurally" the best way to go.
                  But in this way I'm constantly making new pointers to always the same old base-object.
                  And because there is only one instance, would it not be clearer to use some sort of "almost-global" object, such as a module-constant, and have access to it anywhere in the program?
                  Like TT does?
                  And after thinking on this, maybe TT's way of just making a module as a base-object for the plugin is a better approach than my BimTools-class. Because is't only used once, the module-approach seems more fitting...
                  Something like:
                  module Brewsky
                    class BimTools
                      def initialize
                    class BtProject
                        dialog = PLUGIN.web_dialog
                    PLUGIN = BimTools.new
                  • Dan RathbunD
                    Dan Rathbun
                    Here is a SketchUp specific example of using a Constant Library mixin module so an author's various plugin modules (and/or submodules,) can share the references to the author's menu and submenu objects.
                    See: One Submenu for many plugins
                    πŸ’­
                    • brewskyB
                      brewsky
                      @dan rathbun said:
                      So for example, your nested module Brewsky::BimTools::Manager is actually an instance object, and the preceeding identifier is the reference to the instance.
                      If you remember this... then it can be easier to understand how using an anonymous singleton proxy class instance inside your Module class instance, makes sense.
                      Thank you very much for this very helpful post!
                      I completely missed it untill now 😳
                      My plugin is in need of "some" improvement... πŸ˜‰
                      • Dan RathbunD
                        Dan Rathbun
                        Oh hell yes.
                        If you need only one copy of a code object, then generally it should be a module.
                        If you need multiple copies of a code object (usually because the code must adapt to many other instance objects,) then you make it a class, and instantiate instances that are syncronized to a particular instance object.
                        Often coders try to avoid using a module, because they think it's a static kind of object, and they believe it is harder to use than a class instance.
                        What they miss is, that a module definition, is really an instance of class Module. So for example, your nested module Brewsky::BimTools::Manager is actually an instance object, and the preceeding identifier is the reference to the instance.
                        Imagine the Module class is "the hen".
                        It lays an egg, which is your nested Manager module instance, that could be created thus:
                        ` Brewsky::BimTools::Manager = Module.new {
                        plugin managerial code here
                        }But the Ruby interpreter calls the new()` constructor for you on the C-side of things. (Ie, the defintion block syntax for scripts, was invented for human happiness and readability; Ruby itself does not really need it.)
                        But having methods in modules communicate (call each other,) works a bit different than in a class definition. Instance method definitions in a module, are meant for Library Mixin modules. (Read up on the include and extend methods.) They become different kinds of methods, depending on whether they are mixed into a class or module, and whether include and extend is used to do the mixing.)
                        So at first blush, the coder thinks they must define all methods in a module as module functions that must be called with self.method_name(), ... they find this cumbersome, and they switch back to using a class defintion, and using only one instance of it. (A sort of psuedo-singleton class.)
                        BUT.. the egg can have a membrane inside it's shell. This membrane analogy is the anonymous singleton proxy class instance created with the following syntax:
                        module Brewsky
                          module BimTools
                        module Brewsky;;BimTools;;Manager
                          # module variables and constants declared here
                          MGR_VERSION ||= '1.2.3'
                          @@bimmenu ||= nil
                          class << self # self evaluates to the module instance
                            # Everything in here acts like a class
                            #  instance BECAUSE IT ACTUALLY IS !
                            # In here we can access the module @@vars directly.
                            # In here we define instance methods, not module methods.
                            # But if they are public, they can be called like module
                            # functions, from anywhere outside the module.
                            private
                            def get_version()
                              MGR_VERSION
                            # In here we can call any other method in here,
                            #  without module qualification.
                            public
                            def version()
                              get_version()
                          end # proxy class
                          # Out here we can call any of the methods inside
                          #  the proxy class directly, without qualification.
                          unless @@bimmenu
                            @@bimmenu = UI.menu('Plugins').add_submenu('BIMTools')
                            @@bimmenu.add_item('Version') { UI.messagebox("BIMTools ver #{version()}") }
                        end # module Brewsky;;BimTools;;Manager
                        # 99.9% of the time, there is no good reason to
                        # have any executing code outside your namespace.
                        πŸ’­
                        EDIT(2012-12-16): changed post title to "Why use a module instead of a class ?"
                        • 2 / 2
