    Color interpolation across a face
    14 Posts 4 Posters 1.6k Views 4 Watching
      ArunYoganandan
      @dan rathbun said:
      You might use THAT image as a material applied to the face. Then adjust the corners of the material image to the face's vertices. ??
      Hi Dan,
      Thanks for your reply. What I'm trying to do is build a sliceable color cube like
      http://www.sonycsl.co.jp/person/nielsen/visualcomputing/programs/colorcube-1.png
      This is an immersive system and the user would be able to grab a corner and move it within the original cube's dimensions in 3D to
      indicate the color desired. i.e, position 0.4,0.1,0.3 within the cube will denote the corresponding RGB values.
      When the corner is moved, the faces will also correspondingly change in shape/fragment (Exactly like how it would behave when the vertex of a cube is moved in sketchup)
      revealing new colors at the depth (like slicing a volume with interpolated colors).
      Simply put, the faces of the cube get modified to different configurations and hence I will not be able to use a static texture. Something like a GLSL shader would be perfect except I don't think we could do that in SU?
      Thanks,
      Arun
      • Dan RathbunD Offline
        Dan Rathbun
        If you know the binary fileformat for some image filetype, you could write out a file in binary mode:
        ` img = File.open('myimage.bmp',"wb")
        img.write(value)
        img.close`
        Then bring that image into your materials collection.
        I'm not here much anymore.
          Dan Rathbun
          Hmmm.. I'll need to think on that...
          Have you been following what Aerilius' OnScreen GUI Toolkit
          or: Chris Fullmer's On Screen GUI RGB Colorpicker
            Dan Rathbun
            To draw in OpenGL style (either 3D or 2D,) in SketchUp, must be done within a Tool class, using the View instance's family of draw methods.
            see:
            https://developers.google.com/sketchup/docs/ourdoc/view#draw
              Dan Rathbun
              So.. for color interpolation within a Tool class, when you set the color (just prior to painting a point,) with view.drawing_color=() you would evaluate the argument using color.blend
              The receiver color would be color of one vertice, arg1 the other vertice's color, and the weight arg would be percentage ( Float) of the distance between the two vertices.
                The API doesn't let you set vertex colour. 😞 Wish it did.
                  Dan Rathbun
                  That's not what he wants.
                  He wants to draw multi-gradient color fill, on-the-fly.
                    Yes - and in OpenGL you do that by defining a colour for each vertex in a polygon where the shader then creates a gradient between each vertex colour across the polygon surface.
                      Dan Rathbun
                      Yep.. it would be nice to have more OpenGL draw functions.
                      Implementing a shader in Ruby is bound to be slow.
                        Aerilius
                        @dan rathbun said:
                        ... you would evaluate the argument using color.blend
                        color.blend makes brown out of red and green.
                        In case you need a different interpolation (where you want red and green to result yellow), you need to write your own interpolation method, or take Color.interpolate(color1, color2,...) of https://bitbucket.org/Aerilius/color/wiki/Home
                          ArunYoganandan
                          Thanks everyone for the replies.
                          @Dan using the draw in a tool's view method looks like a plausible option. Let me dig into it and get back.
                          Thanks again.
