    Getting and iterating scene list?
    16 Posts 3 Posters 1.2k Views 3 Watching
      @thomthom said:
      Doesn't sleep freeze up SketchUp itself?
      Yes it does.
      puts 'foo'; Kernel.sleep(5); puts 'bar';
      SketchUp doesn't respond at all until sleep is over.
      • Dan RathbunD
        Dan Rathbun
        It should not freeze the C++ side, which should continue animating or zooming the camera. It should only pause the Ruby interpreter.
        And I likely showed more time than is needed in at least the first place in the example. The second place is dependent upon how many pages need updating thumbnails, etc.
        I'm not here much anymore.
        • Dan RathbunD
          Dan Rathbun
          @thomthom said:
          Yes it does.
          Apples and Oranges.
          puts is on the ruby side, ... of course sleep will pause between the two Ruby statements!
            @dan rathbun said:
            @thomthom said:
            Yes it does.
            Apples and Oranges.
            I should have been more specific - I cannot interact with SketchUp until sleep is over. The puts statements where just visual clues to know when it was over.
              You didn't test it, did you?
              • Dan RathbunD
                Dan Rathbun
                It's probably not perfect,.. and I did say this:
                @dan rathbun said:
                If this does not work correctly.. then we'll have to implement a FrameChangeObserver.
                I'd likely use a UI.start_timer block along with a FrameChangeObserver if the sleep did actually interfer (perhaps SketchUp cannot call ViewObserver or PageObserver instances during sleep call ??)
                So.. you could be correct Thomas. This the ol' workaround thingummy again. I wish the API would finish doing certain things, before returning a value from many API method calls (like setting pages, etc.)
                • Dan RathbunD
                  Dan Rathbun
                  Nope.. caught me!
                  I just whacked it out. 😳
                  I'll have to drink another cup of coffee, and put in a FrameChangeObserver
                    Rember, we cannot even use Ruby threads without blocking SketchUp. And wouldnt it be difficult for the Ruby engine to interact with the SketchUp engine and the entities if they ran in a separate thread/process?
                    • H
                      HPW
                      OK, things seems not so easy.
                      The scene tab even does first appear after a autosart ruby has run, so no way to access the scenes via shortcut.
                      Other idea: Scenes can store the camera loctation. So can a ruby calculate a new camera location for each scene and write the property.
                      This would not update the screen or change the visible scene. But next time the scene-change is used it updates to the new location.
                      And the new camera locations are stored for each scenes in onSave.
                      What Propertys does ZoomExtents set? Is there a equivalent in ruby to calculate the values in the same way?
                      Regards
                      Hans-Peter
                      • H
                        HPW
                        This does what I want:
                         model = Sketchup.active_model
                         pages = model.pages
                         pages.each {|page|
                            pages.selected_page = page
                            UI.messagebox("Scene; "+page.name)
                            view = model.active_view
                            new_view = view.zoom_extents
                            status = page.update(33)
                        But I have to press OK on the messagebox when scene-update has finished.
                        Edit: Kernel.sleep does not work for that.
                        • Dan RathbunD
                          Dan Rathbun
                          Yes.. I guess we decided it would not, because the C++ engine cannot call observers, as the scene changes, etc.
