    Floor plugin
    11 Posts 3 Posters 954 Views 3 Watching
      dvd63
      Does anyone have suggestions for a plugin to do floors: the type deploy components on a surface with control distances between them?
      thanks
        Jim
        You're question is a little cryptic, but it sounds as if you could use the Move tool to make a linear array of your Components.
        http://support.google.com/sketchup/bin/answer.py?hl=en&answer=94867
          dvd63
          Hi Jim,
          Excuse me, maybe for my bad English. I attach two images to clarify thinking.
          F1 One or more components that must be distributed within a face.
          F2 cutting components and management of space between components inside the face.
          Thanks.
            Maybe you can make somthing with Stepping Stones by Sdmitch
            But seems the "cutting part" will be not made!
              dvd63
              Hi Pilou,
              but it is not a face is a path ...
                No problem just draw some parallels and use them as path πŸ˜‰
                or some ideas πŸ˜‰
                by Jeff Hammond
                [flash=560,315:3mosznlj]http://www.youtube.com/v/HO1Qdd-SiGM[/flash:3mosznlj]
                  dvd63
                  Pilou you think it's unlikely that any of the great masters will be able to make a plugin for flooring?
                  I think it's a very interesting thing.
                  Ciao.
                    We are good agree with that the plugin must do ?
                    Seems that yet must existing...i must refound it πŸ˜„
                    Click for entiere image πŸ˜„
                    Maybe Take a look at Street Generator by Thomthom
                      Else in V8 Pro : a simple boolean diff can make the trick , no ? πŸ˜„
                        and Protrude by Jim Foltz make this : you must draw first the perpendicular cross lines first but it's not a such work πŸ˜„
                        In One direction you have the funny Edge Tool / Divide surface by Thomthom
                        where you can move an edge (the * or / are possible) cutting is automatic! β˜€
                        So a workflow can be: Copy the surface , on each apply the Thomthom plug (on each different perpendicular of course), and paste them πŸ˜‰
                        All that take 5 seconds! Or less if you have made a shortcut on the Thomthom plug πŸ’š
                        And better in V7 as the instersections of cross lines is also automatic πŸ˜’ πŸ˜‰
                        click for zoom
                          Else look Slicer 5 for V8 by TIG seems it has plan of slice XY, XZ, YZ, πŸ˜‰
                          So a double slice ? πŸ˜„ I will test tomorrow on a modern computer πŸ˜‰
                          Works fine! πŸ˜‰
