    Figured Mahogany
    32 Posts 7 Posters 3.0k Views 7 Watching
    • beginnerB Offline
      beginner
      Splendid... πŸ‘ πŸ‘ πŸ‘
      Regards, SU 'beginner'
      • pbacotP Offline
        Nice Dave, just one thing how do you find images of wood that nice without having to stretch it to much to match the length of piece in your drawing and do you use a different image for each piece in the drawing? I know that was two things sorry.
        Thanks Kurt
        You can take a couple of these pieces and make a longer texture in Photoshop by joining them and blending the joint. If the piece is that large you are not going to see it that close anyway in a picture, if the joint is not super.
          That's true, Peter. The proverbial board stretcher. πŸ˜‰ Fortunately I don't need it very often
          • KrisidiousK Offline
            Krisidious
            Beautiful...
            By: Kristoff Rand
              Thank you, Kiristoff.
              I decided to have a little play in KT. I'm short two legs. πŸ˜„
              http://farm9.staticflickr.com/8041/7916192216_c95049f182_z.jpg
              I don't know why the dowel holes appear to be illuminated from inside. πŸ˜•
              • N Offline
                notareal
                Perhaps back faces?
                  What do you mean? As in exposed back faces? Never! πŸ˜„ I don't leave faces reversed in my model and they aren't in this one. I did a higher level render; 8 instead of 7 and they rendered a bit darker but they are still kind of light for holes.
                  • HumpmetwiceH Offline
                    Humpmetwice
                    Just a little test trying your method out Dave.
                      Nice. How long is the "board" image?
                        Humpmetwice
                        Its a standard 2"x8"x8'
                        • pbacotP Offline
                          That's beautiful Dave. Do you ship the kits? Prefinished? πŸ˜‰
                          Nice board Kurt.
                            So Kurt, did you take a photo? Or did you use some other method? What species?
                            Peter, sure, some assembly required. πŸ˜‰
                              Humpmetwice
                              Found it on the web and its pine. I'm not sure I have the "make your on material" thing right tho. Where talking about adjusting the size here Dave or doing something different?2012-09-03_090306.jpg If this is right do you save each material like this to be used in other models?
                                When I create new materials, I know at least one of the dimensions of the board from which the image is made. So in the case of my figured mahogany, I know the length of those images is 66 inches. I don't know the width of those images but it doesn't matter. In SketchUp I draw a rectangle with that known length. Since the width isn't important, I just make it something convenient. In the case of the mahogany images, they are vertical so I drew the rectangles on the ground plane with their long direction parallel to the green axis. these rectangles automatically take care of the size of the material. I import the image as a texture clicking in the lower left corner and dragging to the opposite end. Don't drag to the opposite corner or the dimension will be incorrect.
                                That's all there is to it. You could apply the material to any face and then edit its dimensions in the dialog as you show but I think my method is easier. Although my first image shows the five material images at different widths, when I imported them, I drew a single 66"-long rectangle and made four copies of it. If you wait to edit the materials after they've been imported, you would have to hit every one. Well, that assumes you have more than one you are importing.
                                FWIW, the original images are of unfinished wood. I add the finished color by painting a layer in the image editor with a stain color and adjusting its transparency until I'm happy with the appearance.
                                By the way, that cherry material that comes with SketchUp ought to be about 6 inches square and not 6 feet. Even so, it isn't very convincing.
                                  Humpmetwice
                                  Cool that means I'm on the right track because that basically what I done. Thanks Dave
                                    You are on the right track, then. πŸ‘
                                    • massimoM Offline
                                      massimo Moderator
                                      How is made the material in Kerkythea?
                                        I replaced the material with one from the plastic set. Then I replaced the orange color with the mahogany texture image. I find the process works well and it is an easy way to add some shine to the surfaces. My last render didn't seem to show the glow in the holes all that much and I'm fine with that.
                                        • massimoM Offline
                                          massimo Moderator
                                          Ok, that's a good start. πŸ˜„
                                            It works well enough for me for the one or two renders I care to do in a year.
