    2d photographic poplar tree
    15 Posts 6 Posters 3.0k Views 6 Watching
    • john2J Offline
      john2
      hello everyone,
      I'd like to share a 2d poplar tree that i made. It's a high res 2d photographic tree. hope you'd find it useful. there's hidden centerline so that to place tree accurately.
      http://www.sendspace.com/file/537kug
      Sketchup Make 2017 (64-bit), Vray 4.0 , Windows 10 – 64 bit, corei7-8750H, 16GB RAM, Nvidia GeForce GTX 1050Ti 4GB
      • micioneM Offline
        micione
        very useful.
        thank you very much
        • W Offline
          wyatt
          John,
          That's a great looking tree. Thank you. I hope you don't mind, but I modified the component so that the tree would cast an accurate shadow.
          http://www.sendspace.com/file/uedkmb
          • john2J Offline
            john2
            oh wow!!, thank you !! πŸ˜„ you manually drafted each stroke or used some outer contour detection software?
              RICALBUR
              Thank you very much
              • beginnerB Offline
                beginner
                I had a go to see how good the shadow could be.
                Attempt attached. 😎
                ❗ Use with Caution ❗
                The shadow could stretch some older computers.
                poplar_with_shadow_small.zip
                Regards, SU 'beginner'
                • W Offline
                  wyatt
                  John2, I used the freehand tool to create the general outline of the tree and the larger gaps on the interior. It appears that beginner spent a lot more time doing that, or used a different method; perhaps exporting from photoshop/illustrator as described by my friend, John Pacyga, http://sketchupland.posterous.com/tree-component-process and Alan Fraser: http://forums.sketchucation.com/viewtopic.php?f=18&t=6687&p=42648
                  • john2J Offline
                    john2
                    a faster way , a lot faster is to import the alpha map of it in illustrator, use the live trace feature to trace the outline. voila, then export to dwg. simple 😎 πŸ˜„
                    livetrace tutorial here πŸ˜„
                    • W Offline
                      wyatt
                      That method works for Pro users who can import dwg. Free users would have to use one of the other methods. Thanks for the tutorial links.
                      • john2J Offline
                        john2
                        my pleasure πŸ˜„ .
                        • pbacotP Offline
                          John,
                          [attachment=0:2qy7uf4n]<!-- ia0 -->Poplar with shadow.jpg<!-- ia0 -->[/attachment:2qy7uf4n]
                          Hi this looks great, John. However when I download it is a "EXE" file that my Mac cannot decompress. Can you please post it here as a zip? If you have a minute. thanks
                          • john2J Offline
                            john2
                            @pbacot said:
                            John,
                            [attachment=0:1ap37z3x]<!-- ia0 -->Poplar with shadow.jpg<!-- ia0 -->[/attachment:1ap37z3x]
                            this link downloads an skp. how come ur getting exe?
                            • john2J Offline
                              john2
                              here's the file split up as part 1 and two . open with winrar. cheers!
                              Poplar with shadow.part1.rar
                              Poplar with shadow.part2.rar
                              • pbacotP Offline
                                Thanks John. It looks great. I bet I can use this. Regards, Peter
                                • john2J Offline
                                  john2
                                  you're welcome pal, a lot of stuff this forum has provided me too . i became an advanced user by reading these forums. literally, some people have dug sketchup inside out πŸ‘ . πŸ˜„ . i'm thankful to all the great great people who have provided huuuuge number of useful plugins here. πŸ˜„ πŸ‘ πŸ‘
